Thread: Clutch noise
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Unhappy Clutch noise
    Hey,
    When i push the clutch whilst out of gear there is a slight grinding noise. There is no noise whilst just ticking over and no noise when clutch all the way down, only half way.
    Bearing, new clutch?
    Bristol
    That noise is usually the thrust bearing, but you normally only find it when you have your foot off the clutch pedal.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    could be the DMF
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    I bet alot of
    money it will be your DMf (dual mass flywheel) only cure is to replace it
    Independant local garage 600-900quid
    vauxhall dealer 1000-1400 quid
    diy free but parts are 250-350 and it's a big old job to do if your not clued up
    Regular Member DaveW555's Avatar
    Cannock
    If there's no noise when your foot is off the pedal it is more than likely going to be the concentric slave cylinder, the noise you describe doesn't sound like flywheel, thats more of a rattle than a grind. The only cure for it is gearbox out and a new slave cylinder, while the box is out it might be an idea to check the flywheel and clutch as your going to be paying virtually the same labour as if you were changing them anyway.
  1. Clutch noise
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 29th April 2011, 10:25
  2. noise on clutch
    By gasrac in forum Engine & Drivetrain
    Last Post: 24th May 2009, 18:39
  3. Clutch noise?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 18:20
  4. Noise on clutch
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2008, 11:54
  5. Clutch Noise / Kit
    By robzc in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 08:11
