Results 1 to 10 of 11
Thread: 2.2 Direct Petrol unstable acceleration
    North Wales
    Default 2.2 Direct Petrol unstable acceleration
    I have an 04 2.2 z22yh engine vectra and I'm now pulling my hair out. Last week the car went into get you home mode warning lights on. Had a mobile mechanic look at it ran the diagnostics which showed Air Mass fault. This was changed, it then showed faults on Cylinders 1 and 4 the coil pack was changed. Its still doing the same fault. Basically when accelerating it feels as though its misfiring. The car is jerky to drive and struggles to reach anything above 4000 RPM no matter what gear is used. Does any body have any ideas. There are no fault codes in the ECU as these cleared after the air mass was changed.
    Please help
    Regular Member steve.s's Avatar
    Mar 2007
    spalding, linc's
    has it been in for the fuel pressure reg recall
    North Wales
    No idea car was bought in Feb didn't have much service history.
    Mar 2007
    spalding, linc's
    may be an idea to ring your local dealer and say you have heard of this recal and if your car is affected, give them your reg and they should tell you, hope this helps
    North Wales
    Worth a try just banging my head against a wall. Serviced it in feb changed the spark plugs again before just in case one was faulty, cheers
    essex
    My car is doin a simular thing atm and i found it to be an ijector wiring issue! Not sure if it helps but the car is jerking around and has lost all its power and just runs dead slow!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by richiem View Post
    Common problem on the CDTi mate but not the 2.2 petrol. It'll be the HP pump or Reg for sure.
    Regular Member Sambor's Avatar
    Elgin
    What about timing chain mates?How much You got on the clock.I changed my timing chain,timing balance chaine and water pump.Car is much different.More power(it means came back to his roots) and going smooth from gear to gear.But can be something different.
    LARBERT
    My vectra Z22Yh did the same replaced plugs twice, coil pack twice EGR, had FPR done on recall, still ran like a bag of spanners turned out as last resort bought the continental fuel pump swapped over and car ran smooth, and after 3 short runs, with restarts, EML light went Off.
    Mar 2012
    bath
    Hp fuel pump oil seal popped I had it on mine till I rebuilt the pump get fuel pressure tested should be 5000 kpa
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. Signum 2.2 Direct - misfire?/vibration/poor acceleration
    By Fenris in forum Engine & Drivetrain
    Last Post: 31st July 2011, 23:32
  3. Help 2.2 Direct Stuttering under hard acceleration
    By Geordie2.2 in forum Engine & Drivetrain
    Last Post: 22nd June 2008, 04:08
  4. sri 2.2 direct petrol
    By topgun in forum Petrol Engine related
    Last Post: 17th June 2008, 11:05
  5. 2.2 Direct Petrol or 2.0t?
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 10:23
