Thread: Check brake light switch
    Regular Member dolf.peeters's Avatar
    Nov 2009
    Eire
    Default Check brake light switch
    any idea what I do with the above error showing on the onboard? apart from pressing ok?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does it actually say check brake light switch?
    Nov 2009
    Eire
    it does and shows a symbol of a swith like this one , only in a circle
    Glasgow
    Ohhh very fancy never knew they done this. The brake light switch will be above the brake pedal, might aswell buy a new one and fit it should'nt be expensive.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    This switch is used for putting the brake lights on when you press the pedal and I think the cruise control uses it to disengage the cruise once brake is pressed
    Check the connectors and replace if needed
    Press the pedal does your brake lights come on and if you have cruise control does it cut out when the brake is pressed
    ROCHESTER, KENT
    Default check brake light switch
    I have just had the same problem with the same display.
    I took my car (2005 Vectra C tdci ) to my local garage to have it code read. They only had a Bosch machine but it indicated 10 faults and would not let them be rest.
    I then contacted a Auto Electricia who had tech 2 equipment, he found that this fault was caused by a blown fuse - F14 in the fuse box in the engine compartment. Fuse replaced, faults reset and all ok. cost £25
    I now have a couple of spare fuses "just in case"
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yip and was actually the cause of my cruise control woes. Still get the warning occasionally, just means the switch needs recalibrating - so a mechanic told me.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Gazza4 View Post
    You read the date on this bud
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    get this lots also with other simular related faults, just clear it (ok), in most cases its just a glitch.
    middlesbrough
    Quote Originally Posted by the-wizard View Post
    ive got the same problem i get the brakelight switch warning on display, and the brakelights work for 2 secs then go off if you then press ok on display brake lights start to work again but go off again after 2 secs, after doing a few cheks a fuse was blown nex to glove box so i replaced it , worked perfectly after thAT for 2 days and then the fuse blew again and same prob occured, im now changeing the fuse every 2 days until sum1 on here who has had the same prob repaired can advise me
  1. Check Right Brake Light
    By Dobs in forum Engine & Drivetrain
    Last Post: 20th October 2012, 09:13
  2. Check brake light switch = no turbo?!?! HELP!!
    By se4 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2012, 21:21
  3. Check Brake Light
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 11:15
  4. Brake Light Check
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 22:11
  5. Check 3rd Centre Brake Light
    By Downunder in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2007, 16:14
https:www.vectra-c.comforumshowthread.php114016-Check-brake-light-switch
check brake light switch vectra c
how to check brake light switch zafira
vauxhall vectra brake light switch
vauxhall astra sri brake light switch warning
2005 vectra brake light switch
vectra c brake light switch removal
vectra cruise control not working brake lights stuck on
vauxhall vectra c brake light switch
vauxhall vectra C stop-light switch
vectra brake lights stuck onwhere is.breaklamp switch on vectra cvauxhall vectra rear brake lights not workingchanging brake switch in Vauxhall vectra 1.8How does the brake pedal switch off the cruise control on a vauxhall vectra autobrake light switch on vauxhall vectra 2005 model locatedbrake light switch on vauxhall vectra 2005 modelvectra c check brake light errorwhere is the cruise contro pedal switch on Vectra Cbrake light switch vectra c mit jelentvectra c brake light switch faultvectra c brake lights not working when engine runningbrake light switch opel vectra cbrake light switch check opel astra h
