Thread: Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    Mar 2007
    Romania
    Default Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    Hello,
    I am getting the following error: B3109 - Remote-Key 1 System Voltage Low Voltage
    Also the central lock system doesn't work...
    The engine starts without problems, what could be the problem?
    Please let me know. Thanks
    Costi
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    have you tried read the error? as its very clear...
    Mar 2007
    Romania
    Does it mean i have to change the battery from inside of the key?
    Engine : 2.2 Direct
    Correct
    Mar 2007
    Romania
    ok, i just replaced the battery, syncronized the key with the car, the key still doesn't function, i put the battery into the second key i have, the second key works perfect...
    what sould be the problem?
    WGAF#5
    possibly that the first remote key has had a knock at some stage and isnt working correclty and is therefore giving a false reading
    i suggest you relegate this one to the spare key drawer for use in emergencies only
    Mar 2007
    Romania
    that is not a nice thing... so there is no way to have the key fixed?
    Regular Member vectraboyy's Avatar
    Mine did this..turns out there was a tiny strip of metal connecting the battery missing.
    Have a look inside, there should be a lil strip where the battery goes around the edge.
  1. Error P0425 Exhaust Gas Temperature Sensor High Voltage
    By dieselman in forum Engine & Drivetrain
    Last Post: 29th April 2013, 22:30
  2. what voltage is the cig lighter
    By bunsen1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2011, 07:29
  3. B1330 - System Voltage MalfunctionB1330
    By black sri1.8 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2011, 19:08
  4. B1330 - System Voltage Malfunction
    Last Post: 6th March 2011, 01:06
  5. P0560 - System Voltage Low Input
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 18:05
GM DTC B3109-00
b3109 fault code
b3109
opel b3109
b3109 code
GM B3109opcom error 00088Opel DTC B3110-00Opel DTC B3109-00 Obd B3109Vauxhall DTC B3110-00opel b3109 codeVauxhall frontera low voltageb3109-00vauxhall zafira fault b3109op_ cam error: b3109 remote key 1 system voltage low what does this meansvauxhall code key voltage low whyvauxhall astra 2013 b3109vauxhall astra b3109b1330-00 vauxhallcode defaut OPEL B3109b3109-00 astrab3109 errorvauxhall astra code b3109https:www.vectra-c.comforumshowthread.php114012-Op-Com-ERROR-B3109-Remote-Key-1-System-Voltage-Low-Voltage
