Thread: air flow meter
    sidcup kent
    Default air flow meter
    1.How much labour should i be charged to fit one of these on a vectra 1.9 cdti 150, is there much involved
    2. how can you physically check to see if the EGR is seized open or shut . i've had new inlet m done and still no power turbo not kicking in, no smoke checked all hose's and pipes puzzled
    soz not machanically minded
    thx jim
    WGAF#5
    if you have air flow faults then this would prevent the car driving at "full power"
    to change the air flow meter (MAF sensor) - model dependant - undo 2 screws, remove a wiring retaining clip and then remove - fit new and reverse of above... 5-10 minutes max ...then test it
    sidcup kent
    cheerz deztroyer if i have air flow probs would it cause the turbo not to kick in, or could the egr valve be causing the turbo not to kick in
    WGAF#5
    if the MAF sensors not working correctly then it would restrict power -which would affect airflow and the Turbo's operation -
    have you read the fault code?? becuase the sensor not working could be down to an air leak rather than a sensor fault
    sidcup kent
    ok bud will check that out thks
  1. air flow meter
    By tyler boy in forum Engine & Drivetrain
    Last Post: 17th November 2011, 22:20
  2. Air flow meter ??
    By craig-k in forum Engine & Drivetrain
    Last Post: 12th July 2009, 17:11
  3. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
