Thread: Aux belt tensioner changing.
    swansea
    Default Aux belt tensioner changing.
    How easy is it to do yourself, whats involved.
    Regular Member Jezzy's Avatar
    S.E
    Which engine?
    swansea
    My engine! Good point. 2.2 direct yh.
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    I have the 2.2 DTi and I had the belt changed last week. The mechanic had to access the tensioner from under the car by removing the plastic tray at bottom of engine.
    It didn't take him long but sorry I can't be more helpfull i'm affraid.
    Jon
    S.E
    Copied from corresponding thread about the 2.0T:
    If the 2.2 is the same as the 2.0 in this respect, then take off the front O/S wheel, remove the wheel arch liner to give you access to the belt etc. Push the tensioner up and away from the belt, pull the belt off, undo the hex nut holding the tensioner on, undo the nut holding the crankshaft pulley on, fit the new pulley and tensioner, fit the new belt, run the engine to make sure the belt is fitted properly, refit the wheel arch liner and the wheel.
    swansea
    Anyone have a similar picture of the 2.2 direct engine.
    S.E
    Quote Originally Posted by jrh1 View Post
    http://www.vectra-c.com/forum/showthread.php?t=113109
    swansea
    That looks much easier than Mr Haynes says it is.
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  3. Changing chain tensioner.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2012, 10:50
  4. Aux Belt Tensioner Help !!
    By keithtinman in forum Engine & Drivetrain
    Last Post: 25th July 2011, 21:57
  5. Aux belt tensioner on 3.2
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th September 2008, 21:22
vectra c aux belt t
signum alternator belt change
vectra auxiliary belt
auxiliary belt noise on a vectra 2.2 direct
vauxhall vectra should the auxiliary belt be replaced
vectra c 2.2 direct alternator belt
replacing alternator on a vectra 2.2 direct
how often should i change the drive belt tensioner on a vectra c
2005 vectra 2.2 fan belt change
how to change vectra c alternator belt
Vauxhall vectra 2.2 peyrol alternator tension
changing aux belt on vectra c
how to replace alternator belt on vauxhall 2.2
astra g aux belt tensioner fitting
vectra c 2.2 aux belt removal
how to change auxiliary belt tensioner vauxhall vectra .2.2 petrol
astra g dti auxuliary belt tensioner
vectra aux belt tensioner replacement
2.2 direct aux belt tensioner replacement
vauxhall omega auxiliary belt removal
vectra c alternator belt tensioner
change belt tensioner bectra
signum 2.2 direct belt tensioner
vectra 2.0t aux belt tensioner www.vectra-c.com
2.0 dth auxiliary belt running of centre
