Results 1 to 3 of 3
Thread: Vec C Push Button Start?
    Regular Member arbell's Avatar
    Christchurch NZ
    confused Vec C Push Button Start?
    Hi all,
    just a bit of a technical-Electrical question?
    I am wanting to install a push button start on my 04 Vec C. my question is does the tranponder unit around the ignition barrel read the coded key at the unit or through the ecu?
    I was thinking along the lines of unlocking the doors jumping in placing keys in centre console and pushing the start button , to start the engine.
    ive done it on my 40 series cruiser but, the vectra has the inbuilt immobiliser that i need to get around.
    Any help would be appreciated.
    Andy
    Full Member spennny's Avatar
    Blantyre
    Have a look here mate, discussed at length
    LINK HERE
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    The transponder pick-up, is a coil wrapped around the ignition key barrel.
    It is linked to the CIM module by a two pin connector, so you could always put the coil into your centre console, and thread your key into it that way.
    Then run two fine wires back up to the cim module.
  1. Has anyone else successfully fitted a push start button?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2014, 09:00
  2. think before you push that button
    By hoochydady in forum Comedy & Humour
    Last Post: 25th November 2012, 18:08
  3. Push the button???
    By Big Sig in forum Comedy & Humour
    Last Post: 13th April 2012, 16:30
  4. Push Start Button
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2011, 12:41
  5. do you own a Keyless entry push button start car?
    By hoochydady in forum General Chat
    Last Post: 9th March 2011, 20:10
vectra c installing push button start
vectra c start button
