Results 1 to 3 of 3
Thread: Brake warning light!
    Nov 2009
    telford
    Default Brake warning light!
    Just a quick one guys. Was driving home today from work and the brake wear warning light came on. Check my book and it said front brake is this correct and if so shall i just change the pads or discs too??
    11 Post(s)
    Yes, the wear sensor is only on the front.
    Discs wear down pretty much the same rate as pads these days, also it quite often works out cheaper to buy a disc/pad kit than the items separately.
    You'll also need a new wear sensor as they're not re-usable once they've been activated.
    Regular Member DaveW555's Avatar
    Cannock
    See how big the lip is on the disc, if its hardly noticeable you'll get another set of pads out of them but if its a decent lip change the discs.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
