Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Swapping sat nav from one vectra to another?
    Andover
    Default Swapping sat nav from one vectra to another?
    Is it possible to swap the sat nav from a 2005 SRI CDTI to the same car on a 2007 plate?
    Is it just a case of swapping the units and the screens?
    And does the car without the satnav have the wiring to fit it?
    Many thanks
    WGAF#5
    yep you would also need to make sure there both the same network
    2005 may be half multiplexed (3buttons on both sides of the steering wheel) whereas 2007 should be fully multiplexed (scroller wheels on steering wheel) otherwise there could be issues ...although Kman's recently managed a conversion ....
    and you would also need the roof loom and aerial as these house the gps antennas and associated wiring
    and possibly the radio wiring loom
    hth
    Dez
    Regular Member vectraboyy's Avatar
    you need to unpair it from the other car too. lol
    Andover
    Quote Originally Posted by vectraboyy View Post
    really! hows that done?
    the easy way is to forget it and go buy a tom tom
    Andover
    yeah i know that but ive got all the bits as ive got sat nav in one car and not the other! just need to know the motions of how to swap them over.
    Oct 2007
    Shropshire
    Well assuming you have the looms in your car (a big assumption I think!) and they are both fully multiplexed (canbus radios) the proceedure for a swap would be to go to a garage with tech 2 capability.
    Then get them to devorce both the display and the radio from both cars. (I think you need your code card to do this) after this is done you can then physically swap them over in the cars.
    Then get them too code the radio and display into the respective cars. If the looms are there, all done! Remember you will also need a garage with a licence to devorce parts as some garages don't have it.
    In simple terms, good luck!
    Quote Originally Posted by mucklestone View Post
    Or anyone with Opcom...
    Its how i did mine
    But yeah, the Screen AND the unit both need divorcing or you will not be able to pair them up at all.
    Andover
    sounds like a right handful! lol
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    lol there's a lot of misguiding information here
    First of all they don't need to be divorced from donor car ! as long as you have radio and screen from same car they will be fine reason being for the umpteenth time they are paired together and not paired to the car.
    However if you can get the security pass from donor car it will be a bonus
    If your car is full canbus then it will more than likely have all the necessary wires all ready in place as i think later preface cars have the 32 pin TID screen if not it will be easy enough to fit.
    If your getting all this from a scrapped car then you can strip the roof aerial and aerial loom out this will be easy enough to fit after wards and gives you the OEM look
    Only thing you should check is whether its a NCDC or CD70 radio in the 2005 SRI
    Irmscher Insignia CDTI 130
  1. Thinking of swapping the vectra...
    By PAULMAC77 in forum The 'Off Topic' room
    Last Post: 8th May 2010, 23:30
  2. HELP.....Thinking of swapping to vec c gsi
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 19:51
  3. swapping headlights
    By tony stoney in forum Bodywork & Interior
    Last Post: 1st September 2009, 13:56
  4. Swapping the HUD ????????
    By n30jjb in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2009, 22:54
  5. Swapping Interior 06 to 04 ?
    By CdRsKuLL in forum Bodywork & Interior
    Last Post: 16th September 2007, 23:28
