Thread: display wont turn off
    Regular Member Sauce's Avatar
    dunfermline fife
    Default display wont turn off
    Need some help here please. just stopped the car and took the keys out but the display has stayed lit. Its a ccr 2006 headunit. None of the bittons work on the headunit or steering wheel. Is it goosed or can a sort it??
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    There are a few issues, which can do this...
    Difficulty level does vary greatly.
    In order of simplicity - easy first
    First of all disconnect the battery for an hour or so, to cause a cold reset of the display module.
    1) Check the soldering on the on/off button of the head-unit.
    2) Check and clean ABS module connector (sounds unlikely, but can and does cause issues)
    3) Check all fuses in end of dash panel...fuses 1, 7, 10, 17, 19 and 26.
    4) Screen may be faulty, so will need to be replaced.
    5) CIM module starting to play up. - Expensive to replace...but check earth wires to steering collumn first.
    Usually pulling the battery for an hour or so works for most cases.
    dunfermline fife
    Cheers disconnected the battery and the display seems finenow. what a didn't do was check where the code was for the headunit cause now its in safe mode.
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you have the owners manual pack / wallet, there should be a red and white passport sized card, with the immobilizer and audio security codes.
    Follow the manual for how to input the code.
    If you don't have this, then it will cost about £15 for a new audio pass from your dealers...you will need proof of ownership, before they will give you the details.
    They will need to send off for the card, and so you will need to wait a few days for it to arrive.
    dunfermline fife
    It wasn't ma head unit a swapped with a mate he has the code somewhere. Might be a excuse to get a new head unit! !
  1. turn the key and nothing!!!!!- Wont start
    By Rupster_69 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2013, 13:13
  2. Vectra wont turn over
    By stevie b in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2012, 20:57
  3. please help vectra 2.2 dti wont turn over
    By deano1 in forum Engine & Drivetrain
    Last Post: 20th May 2011, 21:37
  4. HELP!! car wont turn over!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 31st March 2011, 19:08
  5. Blowers wont turn off
    By KieronGSI in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 08:21
vauxhall signum dash display wont turn off
insignia sat nav screen wont switch off
opel display wont turn off
