Thread: turbo priming
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Default turbo priming
    should be getting my turbo back in the next couple of days but could someone shed light on priming it e.c.t,
    also just phoned the guy and he's sayin there must be a fault on engine for it to go like it has, bearing,seals also it's been getting all scratched up inside.
    cant seen oil in any of breathers, what about pick up pipes e.c.t, all new to turbo engines as this is my first one iv'e ever owned and trying to find anything to do with a z20net is near impossible.
    Ashington, Northumberland
    First off new oil and oil filter if you weren't already going to do that. To prime the turbo pour new engine oil into the oil inlet port of the turbo whilst turning the impeller with your finger. A lot of new turbos these days come with a small pot of oil for this purpose. If they don't supply one, about an egg cup full will be enough.
    On initial start up, don't rev the engine straight away but let it idle for two minutes. Whilst it's doing that, check for leaks (oil and exhaust gases). HTH and good luck
    WGAF#5
    as per Garys repsonse ....and you could disconnect the ht leads from the plugs to turn it over without fuelling it in 3 or 4 10 second bursts
    [Ex]Admin Duncan's Avatar
    When I had my turbo reconditioned at Turbo Technics I was told there was no need to prime it/do anything special when reinstalling. Simply new oil and filter as already said and you'll want to get the gasket/copper seal kit from Vx for all the coolant and oil connections. It's about £15 or so and IMO it'd be daft not to fit new ones.
    The oil will circulate quickly enough into the turbo when you start the car, and as you'll only be idling, the turbo shaft will barely be moving so won't need the layer of oil that is crucial when it's spinning at high speeds under boost.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    cheers guys, cant wait to get it back on the road.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    we allways prime our turbo's on all our caterpillar,volvo and MAN diesels before initial start,no oil means WEAR.
    lincoln
    every time ive replace a turbocharger i take out the fuel pump fuse and turn engine over for 5 secs, so the oil spools round the turbo, turn her off, replace fuse and should be ready to go.
  1. priming light brows
    By 6009tristanb in forum Styling
    Last Post: 16th August 2011, 07:43
  2. priming dti fuel system
    By andy8966 in forum Engine & Drivetrain
    Last Post: 4th May 2011, 16:46
  3. priming shocks?
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:31
  4. Priming and Painting
    By treasure22 in forum Detailing and Car Care Discussion
    Last Post: 6th April 2010, 13:03
  5. Priming !
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 22:54
how to prime a turbo vauxhall vectra
