Thread: Spanner & Car Light
    Wigan
    confused Spanner & Car Light
    Hi,
    The spanner and car light comes on every morning when I start my car from cold, but then once the engines warmed up a bit and been restarted, I wont see it again until the following morning when it's been stood for ages!
    Has anyone any ideas to save me booking it into the stealers to diagnose the fault?
    The car is a 54 plate 120 CDTI Vectra with 125K on the clock.
    Cheers,
    Smithy
    Usual culprit is the glowplugs for what you're describing. Ultimately though a code readout will save guessing and getting it wrong. Have you tried the pedal trick to see if it will show any codes?
    Think mines doing the same. I have a 120 CDTi 05, the spanner comes on and goes off after 3 minutes. If i leave it for an hour or so and start again the light doesnt come on. If left all day at work it will come on and then go off again after 3 mnutes. Cant get my code reader to give any fault codes either. The pedal trick didnt work also
    Jan 2010
    wirral
    99% sure its the glow plug!!
    I have had mine on the reader tonight with the same fault, can't remember the code now. I would not worry one little bit about it, but none-the-less, try and have the fault "read" just to be sure. From experience, i would not worry about the car/spanner light UNLESS the car goes in to limp mode!!!
    My " diagnostic device" said ............."general glow plug error".
    End of the day, theres 4 of them and they're only used during the ignition cycle so if one is dodgy and the car starts ok then don't worry. Worst possible case you have to replace all four at a cost of about £50!!!
    Small change compared to what could go wrong with these engines!!!
    Farnborough, Hampshire
    hmm, interesting, ive got same fault, not tried the glow plugs yet but gonna wait for the code reader to arrive off ebay and see if it can confirm anything. he's right though, shockin the amount some things cost to fix on these cars, makes a me a vary nervous vectra owner now
    Just bought some glow plugs, when i get them and fit them I will let you know how i get on. If your getting smoke on startup also, I have been told it is more likely to be glow plugs. Will keep you all posted, full set of NGK off ebay £37.30 delivered!
    yeah please do let us know if it makes a difference, watching this with interest
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
