Results 1 to 3 of 3
Thread: Air ventilator - removing instructions needed
    New Member Chupo_cro's Avatar
    Hrvatska (Croatia)
    Question Air ventilator - removing instructions needed
    I have some problems with the air ventilator (there is a problem with the deformed shaft) so I'd like to take it out and try to fix the deformed part. I have some air ventilator removing instructions (in words) but apparently there should have been the pictures in addition to the text.
    Can anyone, please, send me the data from the service manual describing the process of removing the air ventilator?
    Vectra 2.0 DTI 16 V, year 2002
    ps
    I have switched off the air ventilation not to damage the motor or the resistor because the rotor is stuck. The ventilator used to work from time to time but now it has been stuck for a while. Sometimes I try to turn it on and I can hear a small change of car engine sound (because of the current thru the air vent coils) so I assume the resistor and the motor are still OK, the only thing that has to be fixed must be the shaft (there was the same problem a few months ago but the problem obviously wasn't fixed as it should have been).
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    It will have rusted up mate, water gets in through the pollen filter because the drain in the bulkhead gets blocked.
    Hrvatska (Croatia)
    A few months ago I had to change the shock absorber spring so I asked to check the air vent too. They took it out and 'fixed' the shaft, the chief technician told me: 'There was a problem with the slightly deformed shaft, we fixed it but not 100% (because there wasn't enough time) so there is a possibility someone'll have to spend some more time (an afternoon) to get it fixed right.'.
    The new ventilator (including the resistor) is about €300 so I really would like to try to fix it by myself without buying a new one.
  1. Advice needed on removing door panels....
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2012, 12:45
  2. Vauxhall Roof Bars-Instructions needed
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 14:07
  3. help needed on removing back door glass please guys!!
    By maddogwhite27 in forum Bodywork & Interior
    Last Post: 30th November 2008, 22:43
  4. I've Been Sent Instructions
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2006, 09:06
  5. Instructions for #21
    By Spikey© in forum Detailing and Car Care Discussion
    Last Post: 14th April 2006, 00:31
