View Poll Results: Has you DMF failed with or without waiting for glow plug light to extinguish.
Voters
45. You may not vote on this poll
  • DMF failure, crank like a petrol
    2 4.44%
  • DMF failure crank after glow plug light goes out
    20 44.44%
  • No DMF failure crank like a petrol
    2 4.44%
  • No DMF failure crank after glow plug light goes out.
    21 46.67%
Multiple Choice Poll.
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Has your DMF failed, pls read......
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default Has your DMF failed, pls read......
    A member PM'd me the other night about his clutch on his 2.2. The DMF topic came up and it got me thinking........
    From my understanding the DMF is a small solid flywheel, with another larger ring around its outside. The 2 parts are joined together with springs, the idea being to smooth the general behaviour of the engine and to try to eliminate and shock when disengaging the clutch.
    Now I know the CDTi's out number the 4 pot petrol's massively, but still you never seam to see petrol DMF failure's, why?
    The starter motor turns the flywheel from the edge, and the CDTi's take more to crank over so more force is being put on the springs in the DMF (this is a question not a statement by the way, please correct me if i'm wrong)?
    So a question really to the CDTi owners, do you start the car after the glow plug light has gone out or do you just get in and crank like a petrol? Is the DMF more likely to fail if you crank like a petrol than if you wait?
    So a little pole.........
    Regular Member VXR_DV's Avatar
    South Coast
    Starting the engine with the clutch fully depressed makes DMF issues crawl away and visit those owners who start with the clutch up.
    Also avoiding fast full-bore 1st-2nd upshifts can help.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I bought my CDTi with a failing DMF, had it replaced last year.
    I always wait for the plug light (and have clutch pressed) to go out before starting with the new DMF, (touchwood) its been spot on - time will tell I suppose.
    Just to add something else, if what you say is right, then other issues that cause starting problems could cause premature DMF failure - i.e. EGR valves.
    PRESTON
    why is the second and fourth option the same?? or am i missing something???
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    i suppose torque output might play a part. i suspect the majority of diesel dmf failures are on boxed and remapped cars - 330 lb.ft is a fair whack.
    Vehicle : SRi
    Mileage : 137000
    i.e. EGR valves.
    Don't bring me into that, i'm not all doom and gloom on the EGR front, mine's blanked and has been for years....
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by barney490 View Post
    Cos i'm a Deacon, Admin!!!!!
    PRESTON
    ahhhh, so option four is,,,no DMF failure crank after glow plug light goes out.
    just a thought,,,,,good plausable theory and be interesting to see the results,, but do petrols have dmf?? im sure the 1.8's dont, anybody know for sure???
    Vehicle : SRi
    Mileage : 137000
    I think none VVT 1.8's dont. Mine has though.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    option 4 is changed.
  1. Failed the MOT :(
    By Coppen in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2012, 18:39
  2. Failed MOT
    By ScotsDragon in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 22:39
  3. Failed MOT on...
    By TomiboyC in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 20:58
  4. Failed MOT
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 6th January 2011, 21:21
insignia crankshaft causeing dmf failure
