Results 1 to 10 of 19
Thread: very poorly veccy c
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    122 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default very poorly veccy c
    Hi everybody, whilst im new to the forum im not new to vauxhalls and have been a member of several forums including vectra-sport, vvoc and omega owners, i will be popping in regularly to aid people in any way i can, but right now i need some help myself,
    i purchased a veccy c 1.8 sri on saturday but it is seriously lacking in the power department, in other words you could not wheel spin it in butter, the emission control light was on and the revs would go up and down and try and stall.
    today i connected opcom and found 29 fault codes so i cleared them and now only have 3 fault codes that wont clear.
    now the strange thing is when i cleared the fault codes the emission control light went out but i have gained a car with a spanner
    these are the fault codes i have and any help would be gratefully received
    P0170 - Fuel Trim System Lean
    (12) - Present
    P1230 - Main Relay Malfunction
    (06) - Present
    B3974 - Driver Door Select Switch Window Lifter Circuit Open or High Voltage
    (05) - Present
    PRESTON
    p0170, start by looking at the mass air flow sensor, see if the wire inside dirty, clean with electrical cleaner, dont touch it with fingers!!!!!!
    p1230, maybe similar issue with throttle body, again, clean,,
    b3974, maybe just a dirty window switch, its covered in the how too section
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by barney490 View Post
    thanks for your answer
    b3974? a dirty window switch? but all the switches on the drivers door work?
    PRESTON
    they might well work, just a suggestion based on high voltage or open circuit, worth checking,
    Sep 2009
    midlands
    hi jon, can i ask you what fault reader you used and where i could possibly get one from as i really dont wanna trip to the stealers as my 1.8 sri is sounding a little like yours did and it has for a while now, cheers buddy
    obviously you cannot post copyrighted details if it is on the forum tho pal, cheers
    Swanley , Kent
    122 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    i will certainly give it a try, as i have nothing to lose, i am a mechanical man and can strip and rebuild an engine but when it comes to tracing electrical problems im at a complete loss
    PRESTON
    op-com, coughs,,,,, ebay, coughsssss,,,,,
    Sep 2009
    midlands
    was after a model no or similar unsure on which is best or work etc
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The last you have.. i also have with no faulty swith or anything, just ignore it. its there probaly because you have had the doorlocking mechanisme changed. and how to tell, if you can lock the driveres door (on the door pin) without the other doors locks.
    Oct 2007
    Shropshire
    Quote Originally Posted by kenp View Post
    I have had mine from new and mine has always functioned like that....
  1. My poorly car is going in I can't take it no more
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 10:27
  2. Car is poorly :(
    By sjk in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2010, 13:58
  3. Is it poorly?....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:22
  4. My cat is poorly.....
    By Harry in forum General Chat
    Last Post: 19th March 2007, 21:16
  5. My pc is poorly
    By ion in forum General Chat
    Last Post: 7th February 2007, 11:53
