Thread: astra H car refused to start p1614 & p1616
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default astra H car refused to start p1614 & p1616
    anyone know what these codes are thanks
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    sorry i think these are b codes not p
    Oct 2006
    southampton
    15 Post(s)
    B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
    B1616 Wiper Rear Disable Switch Circuit Open
    HTH
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    the car refused to start like it was immobilised for 10 mins before I got these codes
    Oct 2006
    southampton
    15 Post(s)
    are you sure of the letter code...
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    dunno m8 done the pedal test on the car....starting to really worry if its the cim
    Oct 2006
    southampton
    15 Post(s)
    P1614 SBDS Interactive Codes
    P1616 SBDS Interactive Codes
    From another list
    B1614 RF mirror horizontal position sensor circuit open
    B1616 RF mirror horizontal position feedback circuit
    range/performance
    Been through about 4 lists and these seem to be most appropriate...
    P1600-P1699 Computer Output Circuit
    Code Description
    P1600 Loss of KAM Power; Open Circuit
    P1601 ECM/TCM Serial Communication Error
    P1602 Immobilizer/ECM Communication Error
    P1603 EEPROM Malfunction
    P1604 Code Word Unregestered
    P1605 Keep Alive Memory Test Failure
    P1606 ECM Control Relay O/P Circuit Malfunction
    P1607 MIL O/P Circuit Malfunction
    P1608 Internal ECM Malfunction
    P1609 Diagnostic Lamp Driver Fault
    P1610 SBDS Interactive Codes
    P1611 SBDS Interactive Codes
    P1612 SBDS Interactive Codes
    P1613 SBDS Interactive Codes
    P1615 SBDS Interactive Codes
    P1617 SBDS Interactive Codes
    P1618 SBDS Interactive Codes
    P1619 SBDS Interactive Codes
    P1620 SBDS Interactive Codes
    P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
    P1622 Immobilizer ID Does Not Match
    P1623 Immobilizer Code Word/ID Number Write Failure
    P1624 Anti Theft System
    P1625 B+ Supply To VCRM Fan Circuit Malfunction
    P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
    P1627 Module Supply Voltage Out Of Range
    P1628 Module Ignition Supply Input Malfunction
    P1629 Internal Voltage Regulator Malfunction
    P1630 Internal Vref Malfunction
    P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
    P1632 Smart Alternator Faults Sensor/Circuit Malfunction
    P1633 KAM Voltage Too Low
    P1634 Data Output Link Circuit Failure
    P1635 Tire / Axle Ratio Out of Acceptable Range
    P1636 Inductive Signature Chip Communication Error
    P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
    P1638 Can Link ECM/INSTM Circuit / Network Malfunction
    P1639 Vehicle ID Block Corrupted or Not Programmed
    P1640 Powertrain DTCs Available in Another Module
    P1641 Fuel Pump Primary Circuit Failure
    P1642 Fuel Pump Monitor Circuit High Input
    P1643 Fuel Pump Monitor Circuit Low Input
    P1644 Fuel Pump Speed Control Circuit Malfunction
    P1645 Fuel Pump Resistor Switch Circuit Malfunction
    P1650 PSP Switch Out of Self Test Range
    P1651 PSP Switch Input Malfunction
    P1652 IAC Monitor Disabled by PSP Switch Failed On
    P1653 Power Steering Output Circuit Malfunction
    P1654 Recirculation Override Circuit Malfunction
    P1655 Starter Disable Circuit Malfunction
    P1660 Output Circuit Check Signal High
    P1661 Output Circuit Check Signal Low
    P1662 IDM_EN Circuit Failure
    P1663 Fuel Demand Command Signal Circuit Malfunction
    P1667 CI Circuit Malfunction
    P1668 PCM - IDM Communications Error
    P1670 Electronic Feedback Signal Not Detected
    P1680 Metering Oil Pump Malfunction
    P1681 Metering Oil Pump Malfunction
    P1682 Metering Oil Pump Malfunction
    P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
    P1684 Metering Oil Pump Position Sensor Circuit Malfunction
    P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1689 Oil Pressure Control Solenoid Circuit Malfunction
    P1690 Wastegate Solenoid Circuit Malfunction
    P1691 Turbo Pressure Control Solenoid Circuit Malfunction
    P1692 Turbo Control Solenoid Circuit Malfunction
    P1693 Turbo Charge Control Circuit Malfunction
    P1694 Turbo Charge Relief Circuit Malfunction
    Regular Member benny's Avatar
    Feb 2006
    dudley
    how old is the astraa ?............ if it is before 2008 the cim will need a sps update vx can do it for you at a cost ......... the program in the cim can go awol and the key gets ignored and it goes dead on the key and wont even turn over .,...
  1. p1614 & p1616
    By Morephun in forum Engine & Drivetrain
    Last Post: 29th June 2010, 14:33
  2. My Wife refused to drive the C
    By Cam in forum General Chat
    Last Post: 13th April 2010, 12:49
  3. Fault code P1614
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2009, 19:27
  4. Insurance payout refused because of mods?
    By ajnt in forum Insurance Chat
    Last Post: 21st July 2006, 09:34
p1616 sbds interactive codes
p1614 opel astra h
vauxhall vectra c p1614
opel astra h 1.7 cdti p0105
vectra p 1614
p1616 vauxhall
astra h p1614
vectra c p1616
opel astra h p1614
p1613 astra hastra 2005 p1614 p1616p1614 code in opel astra h 2005p1614-4 opelvauxhall astra H 1.7cdti fault code p1604vauxhall astra 1.7cdti fault code p1604vauxhall astra p1616p1616 опелOpel DTC P1614-4opel dtc p1614Opel DTC P1614-00vauxhall astra h p1614fault codes opel astra h 1614p1616-00 astraVauxhall DTC P1614-4p1616 opel astra h
