Thread: how do i find air con leak ?
    Regular Member nigec's Avatar
    barnsley
    Default how do i find air con leak ?
    I know my vec c 56 Sri as a leak on the system as someone tried to gas it up but it wouldn't because it showed up having a leak. I know a local guy who does air con , but he says it will cost me 70 quid just to try and find the leak as he has to gas it up and add dye. Does this sound right ? Any advice welcome. Apart from the open the windows ! I'm in the barnsley area .
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    there are some aircon places which use a pressure test rather than a vacuum test.. this way you can hear it blow the air (or whatever they use) out from the leak.. Failing that it is the use of a dye to track it down
    Sep 2009
    Glasgow
    £70 sound about right, had a good look about for prices when the gass escaped from mine, turned out to be the condenser.
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    When I rebuilt the Cavs aircon after a crunch took out the condenser etc, I clamped an old wheel valve into a DIY charge hose, connected it to my tyre compressor and put 50 psi in.
    Initially the gauge dropped, so out with washing up solution on all the joints to trace the leak. Tightened and retested, and held for 30 mis.
    Got it re-gassed and it was fine
  1. DAB where on car do i find this??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2012, 21:21
  2. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  3. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  4. when do we find out !!!!!!!!!!!
    By glynn in forum General Chat
    Last Post: 11th December 2007, 10:27
  5. Need to find someone who said about...
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2007, 20:34
vectra c find a air leak
