Results 1 to 10 of 11
Thread: Does having SatNav on Vec mean you can't fit aftermarket head unit?
    Regular Member Rikkiola's Avatar
    Feb 2006
    Dunstable
    Default Does having SatNav on Vec mean you can't fit aftermarket head unit?
    Was thinking of changing Vec but wasn't sure if the new one has sat nav whether this means you can't change to a aftermarket head unit?
    Also, does the SRI with satnav have the full colour screen satnav?
    Feb 2006
    Dorset
    cant see why you cant , you will obviously loose your navigation though and screen apart from fuel consumption
    Feb 2006
    Dunstable
    ah ok maybe i should have been more explicit... i did actually mean would i lose the sat nav capabilities if i fitted an aftermarket head unit
    Does anyone know which model stereo comes with the satnav sri's and whether it has mp3 capabilities?
    Feb 2006
    Dorset
    If its a CD70 then yes it will do MP3
    hessle, east yorkshire
    you can fit a another head unit in the centre consul inplace of the plastic storage unit. but you must wire it separately from the the oe unit. see pict on changing head units thread posted 4.3.2008, this way you to get to keep the oe sat nav etc. which is very useful.
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Quote Originally Posted by DennisTheMenace View Post
    It should but mine wont read a good brand of CDRWs
    Yes you can change the head but get one that has the option of the steering controls etc.... thats what I am doing.
    Terran
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    Quote Originally Posted by Rikkiola View Post
    Mine has the CD70 with colour screen although I did have a test drive in one with a black and white screen, it plays MP3's as well.
    HTH
    Regular Member siross's Avatar
    Oct 2007
    Quote Originally Posted by steve c View Post
    Sorry for my ignorance pal, could you explain that a little bit better for me please?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by ccsnet View Post
    Terran
    CDR's and CDRW are different, CDR Disacs use a dye as the recording medium, and CDRW use crystals - hence they can be wiped and there are a few CD players which will not play them.
    If you are using CDRW's, then switch to CDR, I have found that the Philips ones work best on mine - and mines is very nit picky - CDR2006.
    Gazza4
    11 Post(s)
    Not had a problem using CDRW's in my CD70.
  1. Aftermarket head unit
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 20:23
  2. Need help for installing aftermarket Head Unit
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 16:00
  3. Help with fitting an aftermarket head unit.
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 19:29
  4. Help with aftermarket head unit
    By siross in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 12:39
  5. Aftermarket Head Unit Conversion?
    By Cheeky_B in forum General Chat
    Last Post: 11th November 2005, 18:50
can you put a cd70 screen in with a aftermarket head unit
