Hi guys, my electric window buttons are sticking and need to be pressed really hard to work. How do i go about taking the door pannel off to gain access to clean or replace the electrics unit?
Cheers, Brad
Cheers, Brad
just pop the whole switch assy out dont take the door card off.
yep - small flat head screwdriver will pop the switch and surrounding cover out - then you can strip it down![]()
thanks guys![]()
and when you do clean the contacts dont use wet and dry as said in the how 2 , just use a simple pencil eraser
Cleaning the contacts solved the problem, the buttons now work perfectly
what method did you use for cleaning the contacts?
