Results 1 to 10 of 11
Thread: Creaking from Underside of car
    Darlington
    Exclamation Creaking from Underside of car
    Vectra 1.8 Design O6 Plate 33k Miles (approx)
    Hi All
    Recently I have a little issue with the Vectra, there appears to be a creaking noise coming from somewhere underneath the car or from around the passenger area.
    I have monitored it a bit, and it only really happens when the car has warmed up, when setting off 1st thing no problem its more noticeable when going over a speed bump or general bumps in the road when driving slowly.
    In a supermarket car park I pressed down on the passenger side wing and bounced the car a bit and the creaking was noticeable, left the car park and the creaking/groaning had gone.
    But now its come back, I donít think that a spring has snapped as Iíve not heard anything go as we had the car out all day prior to me 1st hearing the noise and the car sits fine and handles and drives perfectly well.
    I donít have any facilities to get the car jacked up but I was wondering if anyone could shed any light.
    Many Thanks
    Regular Member DarylAAS's Avatar
    South Shields
    It could be your shocker thats goosed.... is there any oil or visible damage to it?
    Darlington
    Hi many thanks for your reply
    I had a quick look at the shocker (what i thought was it) and there is no visible oil on the main shocker body (from what i can see)
    Also if I do get a trolly Jack where is the correct jacking point, as i dont want to damage the sill a mate of mine suggested the suspension arm as thats how he gets his Astra up, but ive heard on internet forums not to do this.
    Regular Member Jezzy's Avatar
    S.E
    Find the slot where the standard car jack goes, then next to that find flat section of chassis - that's where you can put the trolley jack cup.
    South Shields
    not on the suspension arm!.... as said above or look on the sill and there should be an arrow pointing to the jacking point and it usually has notches out of it aswell....
    Darlington
    Thanks all for the replys and information
    My mate is going to lend me a trolly jack so I can get the wheel off, and look at the shockers (as suggested above) and inspect properly although im a little bit nervous about using a trolly jack as ive never really used one before, and I dont want to damage my car.
    I also want to check and lubricate the rad mounts, on the Facelifts was this still a issue, and can someone advise me on where to look and how to lubricate thanks.
    Thanks in Advance
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Mine has exactly the same sympton on the LH front. If you push down on the wing the creaking is there and only when the car has been driven for a little while. Its there when slowly moving in traffic, disappears under braking and when driving above 30mph.
    Garage has it booked in for Wednesday but last week couldn't find anything wrong, springs on both sides are ok, drop links in good order. I did hit a large pothole in a garge filling station about 4 weeks ago - i wonder if thats caused this problem.
    Darlington
    Thats exactly the same symptoms more or less as mine, however I havent dropped it down any large potholes recently and certainly not on the day it started - i might be brave and get a trollyjack underneath and have a look but i hope its not serious
    Co. Durham
    Engine : 1.8VVTi
    Will let you know how I get on, mines also an 06 albeit its an 1.8 VVT SRi. The suspension is quite stiff on these so trying to do a bounce test can be a challenge.
    As for the pot hole, well it was actually a sunken drain as you exit the Morrisons filling station at Consett. I was only driving slowly but car went with a canny bang as it hit the drop.
    Apart from this issue car is behaving perfectly.
    Darlington
    Cheers much appreciated :-)
  1. Rubber hose on the underside of the airbox ?
    By VecPower in forum Engine & Drivetrain
    Last Post: 3rd February 2012, 13:56
  2. Wax oiled underside of vectra..........
    By Big Red in forum Bodywork & Interior
    Last Post: 21st January 2012, 18:16
  3. What is it hanging from the underside...
    By Don Reid in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2010, 08:43
  4. Pic Request: Underside of bonnet...
    By Leemarksmith in forum Bodywork & Interior
    Last Post: 17th January 2010, 22:48
  5. Rattle noise from rear of underside
    By Mike RB in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2009, 19:20
