Thread: Engine Management Light
    Regular Member Friel's Avatar
    Ireland
    Default Engine Management Light
    Hey,
    I'm having serious problems with my Vectra right now. Its an 02 model, 2.0DTI. The car with the spanner through it light has started to come on really really regularly. Now, at the start it would go away when I turned the car off and back on. But it's gradually starting to affect it more and more when I do that now. The car goes into limp mode when it comes on.
    The other night when I turned it off, when I turned it back on the power steering was gone for a good 30 seconds. It then returned completely to normal till the light came back on a few miles later. I turned it off again and the exact same thing happened.
    Then yesterday, the light came on, so I turned the engine off and back on. But the light stayed on, the power steering was gone, and the accelerator wasn't working. The car wouldn't accelerate. When the lights normally on, it still drives, just goes into limp mode. The light went off when I turned it off and back on again, and I managed to drive home as normal.
    This has only started happening so regularly since last week, so I'm kinda hoping I can get abit of advise before I have to spend my money on a mechanic that could end up just giving me the same advice as you guys.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    i suggest u get it plugged in mate Tech 2, Opcom etc and see what fault codes your getting
    Ireland
    Would a regular mechanic be able to do that? There's not any Vauxhall garages about here that I know of.
    Jul 2009
    Leicester
    any local garage should be able to do it for you. Ive had my brake vacuum pump changed cus mine threw up code P0100. This is a default code if the ecu cannot figure out what is wrong. I had EGR, x2 MAF sensors, boost pipes, boost sensor all replaced and still faulted until now. No problems at all
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
