Results 1 to 10 of 11
Thread: no power is this common
    peterlee
    Angry no power is this common
    i have a 2004 1.9 cdti 150 bhp it ran great til 1 day travelling down the motorway no power thought it must be the inter cooler pipe checked every one nope looked under the injector rail hey presto the bar that links the swirl pots had come off put it back on no difference but on a diagnostic machine comes up every time with this error the swirl pot i can only guess something has gone wrong on there to throw the bar off can anyone please tell me is this a common thing and is it fixable without breaking the bank new owner the car wont rev over 3000 revs and is just about un drivable wont go over 58 mph unemployed just cannot afford dealerships any help would be very grateful thanks
    Worcs/Staffs/Westmids (ish)
    Sounds familiar, try searching the forum a bit if you have time.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Make sure you are sitting down when searching.
    Sounds like the inlet manifold is clogged up and the swirls (as a result) have blocked which pops the bar off (swirl no3 is the controller) - to fix properly it really needs a new inlet manifold, actuator and all ancillaries - a new EGR valve is highly recommended too (as this will have been the major contributor in the fault happening in the first place).
    The job can cost anything between £600 and £1200 dependant on where you go. Some have saved a bit by sourcing the parts themselves and getting a garage to fit - but it is a labour intensive job unfortunately.
    I know you won't want to hear this but alot on here will feel your pain as we've been through it (mine was done last year).
    peterlee
    i had a strange feeling this was going to be expensive where is the best and cheapest place to buy parts from and the fixes you talk about on the forum how do i find out about them as in pic,s do i need to be a full member regards
    peterlee
    where abouts is the egr valve so i can try cleaning
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    150 or 120 bhp m8
    peterlee
    150 bhp
    check on the how 2 section shows you how to clean the egr I have done mine but on a 120 bhp the 150 is easy to get to
    Steve
    You have the 150 engine so you will find the egr bolted to the right end of the inlet manifold as you stand looking at the engine from the front of the car. the valve has 4 fixings holding it to the manifold with a furter 2 holding a pipe under it. Watch you dont lose the gaskets.
    Oops too late.
    Last edited by Rapala; 28th June 2010 at 13:01. Reason: dont know my left from my right.
    Here you go says for a diff engine but the principal should be the same
    http://www.vectra-c.com/forum/showthread.php?t=60856
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. Common problem?
    By Exotica in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2010, 01:47
  3. What do these components have in common?
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2010, 14:52
  4. Most common VXR
    By yorkshireborn in forum General Chat
    Last Post: 9th March 2009, 22:14
  5. Common?
    By rscosworth in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2006, 17:24
