Results 1 to 2 of 2
Thread: Rear arms on siggy
    UkYUk
    Default Rear arms on siggy
    Right I'm doing some tlc on siggy at min as holidays are now over
    right both my rear shocks are past it with oil on there outers so there job 1. Buton inspection found that if I grab reR wheel at 12 & 6 I can rock the arm that is on the top of the hub bearing in it's bushs so that needs doing. What is this bar called ( sounds daft ) is it rear upper control arm or is it a trailing arm. both sides need doing
    Bar is black in colour is fitted on top of hub going direct to the center of the axle has a slight bow in it?
    PRESTON
    yep, upper rear control arm or upper rear suspnsion arm. comes with bushes.
  1. Best place to get rear trailing arms/banana arms??
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 09:53
  2. Rear boomerang arms
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2011, 20:41
  3. Rear Arms
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 20:14
  4. Different Rear Control Arms?
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2010, 15:26
  5. rear top suspension arms
    By BRIANE in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2009, 21:34
vectra c axle hub bush www.vectra-c.com
