Results 1 to 10 of 17
Thread: 2.0T - Timing Chain Change - How Often Please??
    Walsall
    confused 2.0T - Timing Chain Change - How Often Please??
    How often should the timing chain be changed on a 2.0T Vec C (03) ?
    Is it correct that if I go to a VX dealer, they'll be able to give me a complete breakdown of any work carried out on the car by VX?
    I have no idea when the chain and the other gear was changed and the car I've bought has done 94K. Sounds a bit rattley when it's first started from cold but that's for less than 2 seconds.
    Cheers.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If its rattly its time to get it changed mate. And yes, if the car has had any work done on it by any other dealer then they can give you a print out of all the work, its job numbers and costs involved, it will also show you any warranty work done HTH.
    Ashington, Northumberland
    As Rushy says, forget about the timing chain until you hear it rattling. Autodata doesn't even give any info in the timing belt/chain section because Vxl don't specify any replacement intervals. Think of them as you would any other engine component; ie if they aint broke, you don't need to fix/replace them
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by GARY3306 View Post
    If it is rattling now it should be looked at, before it gets any worse.
    Walsall
    Thanks for the replies guys.
    I'm unsure if the rattle on start up is coming from the chain or the aux belt underneath?
    I was thinking maybe the tensioner on the aux belt?
    Vehicle : SRi
    Mileage : 137000
    The chain tensioner is activated with oil pressure i believe, where the Aux belt is just a spring, so the aux belt is always tight. Where as a slack chain will rattle until the tensioner has it's full steam of pressure just after you crank it over, that's my understanding of it.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    The known problem with the auxiliary belt is more of a twittering sound than a rattle, only happens on cold start, goes very soon after moving off, and never recurs if the engine is warm/hot, and is usually caused by the pulley and/or tensioner needing replacement, although if so, it's a good idea to replace the belt at the same time.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    As i thought then
    Irmscher Insignia CDTI 130
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by john_k_sri View Post
    This one?
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Has anyone changed an aux belt on there 2.0T? I get the little tweeting noise when cold. Looking at that pic it doesn't look too hard. I take it you just release the tension and replace the belt? It looks tight to do tho. Looking at the pic I cant see any power steering pump/pulley? Are there an?y other ancillaries this belt drives? If I breaks will it cause any knid of valve train damage
  1. Timing Chain - to change or not?
    By AirCooledHeaven in forum Engine & Drivetrain
    Last Post: 22nd July 2010, 12:50
  2. timing chain
    By oldcommando in forum Diesel Engine related
    Last Post: 23rd August 2009, 19:35
  3. cambelt/timing chain change
    By dgreensmith in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 17:31
  4. 2.2 Timing chain/Oil jet
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2008, 19:19
  5. 2.0 DTI timing chain
    By mzctc7 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 04:23
does Vauxhall 2.0 CDT iengine have chain cam
vectra c timing chain change
timing chain replacement astra 2.0 dti
vectra c 2.0 turbo timing
timing chain vectra c 2.0t
vectra replacement distribution chain
vauxhall zafira 2.0 dti cambelt or chain
opel 2.0t signum drive chain
insignia 2.0t chain or belt
vectra 2 o turbo cam belt or chain
Vauxhall vectra c 2.0t chain problem
timing is out on vectra 2.0
vectra 2.0 turbo timing chain replacement
vectra 2.0 turbo belt or chain
vauxhall 2.2 dti timing chain
vectra 2.0 turbo cambelt or chain
vauxhall signum 2.2 timing chain
vectra c z02 timing chain
vauxhall vectra timing chain change
cam chain problems insignia
vauxhall insignia 09 timing chain
vauxhall insignia 2.0 cdti timing chain
Vectra 2.0 turbo timinG belt interval
timing belt vectra c
signum 2.0t when to replace timing chain
