Thread: spanner on dass
    Regular Member phant's Avatar
    derbyshire
    Default spanner on dass
    I have spanner come up on the dassboard but gose out when engine starts, manuel says may be fuel fillter car has 99.274 miles on and i know cam belt is due is that it any help please.
    Regular Member pugs,signum's Avatar
    swansea
    does it stay on for afew mins when started or go straight out?
    derbyshire
    go straight out
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    think it means its due for a service .its set to come on every so many miles.theres a way to reset it on the how twos somwhere.
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by luke.oldham View Post
    Glasgow
    NO NO lol, if its a car with a spanner then there has been a fault which is not active OR if its a oil can with a spanner then its a service. Neither of them mean the fuel filter needs replaced.
    swansea
    the manual states there fuel filter housing will collect water if the car is used on short runs a lot,
    the spanner through car sign will come up it the filter housing sensor reads that its collected water in it and will need draining!
    according to haynes you should drain the fuel filter housing at (I think) 18000mile intervals
    i drained mine the other week and the light hasn't gone out
    the light stayed on for about 5 mins and went out, read on here it could be glow plugs so checked them with a multi meter and low and behold 2 of them were shot so replaced them and the light lit for 5 mins from time to time so changed the other 2 and light now goes straight out once car starts but still hasn't left the memory after 2 weeks of driving it, so wondering what else could cause the light to come on and go straight out once started?
    As said above for the service, there's a oil can with a spanner that comes on and that can be reset by holding the trip meter down while turning the ignition on and keep holding the trip meter button until it flashes with service and a new mileage! but only do this once you have serviced your car yourself (don't go being naughty now )
    derbyshire
    it is car with spanner on dash and it dose go out when engin starts it it going to cost me big time
    Glasgow
    As the manual states if the car with spanner comes on with ignition and goes off when the car is started there is nothing to worry about. It just means there has been a hiccup somewhere and the fault is'nt active.
    derbyshire
    if this is true how do i turn it off
  1. Spanner
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:09
  2. car with spanner going through it?
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 13:00
  3. My spanner is always on.....??
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 1st October 2009, 18:54
  4. car with a spanner through it?
    By mtcbrown10 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 20:23
  5. Oil can with spanner
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2009, 01:14
