Results 1 to 3 of 3
Thread: Uneven air con
    Farnborough, Hampshire
    Default Uneven air con
    Hi,
    Had my '56 reg 1.9 SRi CDTi Vectra about 3 weeks or so. When I test drove it, the a/c was ice cold and from all vents. The day after I bought it i had vauxhall service it (hopefully not connected to this problem). Just used the air con for the first time today and on the top far right vent, the air was cold, the next vent to my left wasn't as cold, the one next to that was warmer still and the one on the far left was even warmer.
    If i shut off the far right vent, it forced the cold air to the next vent and so on. Its not dual zone climate or anything fancy.
    Any clues what this might be? VX did do an engine coolant change, would that affect the heating system at all? Heat comes out evenly from all vents as far as I can tell
    Dan
    WGAF#5
    which way are the vents directed at the time its uneven ?? you may find that your getting external warm air if its not directed soley at the driver ...
    Hi
    well, any direction really, the one far right is cold and then they just get warmer as you go left across the vents, its definitely the temp of the air coming out of the vents n not the air in the car being circulated
  1. Help with uneven tyre ware
    By wayne10244 in forum Suspension, Wheels & Brakes
    Last Post: 22nd September 2011, 11:52
  2. Uneven Tickover when cold
    By skip85 in forum Engine & Drivetrain
    Last Post: 29th July 2011, 18:17
  3. Uneven Tyre Wear
    By sri/cdti/150 in forum Handling & Braking
    Last Post: 19th February 2011, 11:33
  4. REALLY uneven tyre wear
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2010, 23:25
  5. uneven wear
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 14:42
