Thread: 2.0T Leak!!! Please help?
    Walsall
    confused 2.0T Leak!!! Please help?
    Got up today to find a small pool of coolant at the front of the car on the drivers side.
    Putting my fingers between the gaps under the bumper, it feels like it's coming from a metal pipe/joint at the bottom of the third rad (closest to the engine).
    This is my first Vec C and my first Turbo so I'm a bit lost with this car atm.
    Will it be ok to use rad-weld as a short term solution till I can get the rads out?
    Is this rad I'm on about the intercooler?
    Could the water be coming from somewhere else?
    Any advice gratefully received.
    Thanks.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    chech the expansion tank level to make sure it is coolant first, it could be something else...
    hth
    Midlands Mod Shop - NFFC.
    Walsall
    Yea mate, done that and toped it up as it had lost about a pint.
    Deffo coolant.
    Regular Member SRI_STU's Avatar
    Nov 2009
    solihull, birmingham
    hi mate,
    ive just changed all the rads on my 2.0l turbo. the one your on about is the water rad, its closest to the fan, the middle rad is the intercooler and the front rad is air con. the water rad on the drivers side only has 1 hose going to it at the top where it comes out the thermostat housing, there is also a drain plug at the bottom on the drivers side, it shouldn't of come loose but worth a look.
    Walsall
    Cheers Stu, will have a look at that later after the footie.
    Is rad-weld safe to use on this engine if the worst comes to the worst?
    Just very short of time atm and money cos I'm right in the middle of moving house, slowly lol, so need a quick fix for now.
    Nov 2009
    Ive never had any joy with rad weld tbh, used it on my old mon st200 thought it had done the trick but lost all the water and done the head gasket
    i put a new rad on mine it was £60 from car spares. rather be safe than sorry but all depends, yours might be a hose etc etc
    good luck
    Walsall
    Cheers bud.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
