Thread: Any ideas how to remove this?
    Northampton, UK
    Default Any ideas how to remove this?
    Well, after seeing a few "Gearbox oil" questions, thought I'd change mine, the how 2 on here is great and very easy to follow...
    I loosened the filling bolt first as advised, then went to undo the drain plug, to be greeted by this...
    Attachment 33331
    Its obviously been tried or done before and the bolt hasnt been replaced although it obviously needed to be!
    I syringed a little oil out of the box and its is filthy. I only wanted to replace it with 2.4 litres like the TIS says to help get rid of the notchy 1st to 2nd...
    I tried using WD40 and a shock and unlock spray but no joy, the slightest movement rounds it off more.
    So do you think i'm looking at having it drilled and rethreaded???
    Any ideas on cost?
    Gutted...
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Could try using a dremel or similar to cut a slot for a big screwdriver tip, then use an impact driver on it, or if you have clearance, a beefy screwdriver. So annoying when people do this then just leave it for the next person.
    Jan 2010
    glasgow
    what about a old flat blade screw driver and try tapping it round with a hammer?
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Like above I would slice a notch in with a dremel then get a screwdriver on it and tap it round
    Failing that then buy a new plug I would any way regardless and drill through it with a drill bit get
    a bolt with a left hand thread on it then tap the drilled plug same thread with a left hand tap
    then screw in the left hand bolt and as you tighten it will undo
    Just a case of finding a left hand tap
    and
    bolt of same
    size
    Mileage : 000
    A cold chisel might do it?.
    Ashington, Northumberland
    A hammer and chisel. Works every time. Have your new drain plug to hand though
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    As Garry says just make sure your chisel isn't too sharp
    Regular Member DaveW555's Avatar
    Cannock
    The only thing not mentioned that might be worth a try is to get the next size up torx socket and hammer it in to whats left and see if it bites enough to undo it.
    Regular Member pugs,signum's Avatar
    swansea
    As Winnie2457 said,
    If all fails buy a new plug from stealers then drill through and instead of buying a lefthanded tap and bolt just buy some extractors! heres some on fleabay just need to know how big the thread is on the new plug to know what size ectractor to get! you can buy a complete extractor kit from halfruards but to be honest id buy a good make,
    Im a machinist and the best taps and extactors are dormer so check out the linky iv kindly given
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
  1. Ideas please
    By bigbranno9 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2012, 12:34
  2. any ideas on how to get a bog out car for less than £100
    By barrymanalow87 in forum The 'Off Topic' room
    Last Post: 27th February 2010, 01:33
  3. any ideas ?
    By si_sri in forum Engine & Drivetrain
    Last Post: 1st December 2009, 21:28
  4. Any ideas on how to remove the panal with the heater controls is on?
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2008, 22:42
  5. Any Ideas?
    By gizmo10119 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 20:25
