Thread: Bulb failure in Europe
    Bathgate
    Default Bulb failure in Europe
    How are we meant to travel in Europe in our fine vehicles when it is an offence to drive with a dud bulb and it requires an Opel garage to change the offending bulb? What is the procedure if this happens miles from a garage or out of normal hours,as sods law says it will?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    You carry a spare bulb kit.
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Carry on to nearest gasstation and buy a new one.. atleast not at problem in denmark.. and if on rear on the vec.. another takes over
    Bathgate
    Yeah great. I've got spare bulbs as it is a legal requirement to carry them in Europe. My problem is the fact that the drivers side bulbs require the partial dismantling of my 09 plate Vectra C.
    Engine : 2.2 Direct
    I only have a prefacelift.. and i can change the bulps without taking anything off.. maby the facelift have less space to make it change.. (be happy you dont need a astra.. one of them you ahve to take the frontwheel off to change it....)
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Only changed dip on the Drivers side so far on my Facelift, found taking airbox off the 3 rubbers gave ample room.
    Bathgate
    Thanks Grumpy1954. I'll keep that in mind. My Vectra is same spec as yours.
    Bathgate
    By the way Grumpy1954. Would a K&N panel filter be ok under warranty as it's not Vx part?
  1. Bulb Failure Detection
    By Dhrideruk in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 17:19
  2. Bulb failure.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 10:47
  3. bulb failure warning
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 11:03
  4. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
  5. bulb failure
    By jbr in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 17:11
