Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: 1.9 CDTI fault code P2279-11
    Regular Member mozzer99's Avatar
    bristol
    Default 1.9 CDTI fault code P2279-11
    Hi,
    I have a 2005 vectra 1.9CDTI (150).
    Just bought it at auction (gulp). turns out it was only going well enough to drive slowly through the auction - hmmm.
    It was (and is) very low powered with the spanner light on. It can barely make it up a hill. don't know if limp mode is normally that slow?
    Using this valuable forum I soon found out that my intake manifold was well knackered. Obtained and fitted a new one complete with actuator.
    No difference.
    Op com gives one fault code of P2279-11 intake air system leak detected.
    New airfilter.
    EGR taken off and cleaned, it was free anyway. Using op-com to activate the EGR proved it to be working.
    Checked the intercooler and hoses by putting my hand across the air to turbo intake hose and it had very high suction - presumably if any of that pipework was leaking there would have been little suction?
    Any of you help me where to go next please? Worth many beer tokens (a few mates from work saw me buy it and I can't live it down).......
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    rolleyes
    Got same code and same problem going in to garage on monday to sort out will let you know
    what they find ?
    bristol
    Quote Originally Posted by Driver0069 View Post
    what they find ?
    Plainly I'll be very interested in what they find! Thanks
    Regular Member benny's Avatar
    Feb 2006
    dudley
    dpf is blocking up ....2279 is when the dpf is bloking / blocked and the ecu has no idea where the presh is comeing from ...
    bristol
    Hi Benny,
    I remember you from conversations about my Vectra B DTI four years ago - you gave me the confidence to do my own injector seals (been fine since).
    Looks like I might need to owe you more beer tokens!
    Just a thought -shouldn't the DPF give an error code as a significant difference between the before and after sensors?
    Apart from replacement is there anything I can do to test, i.e. take it out and have a look!
    Big thanks for your help
    PRESTON
    first check it has a dpf, unless its an auto or estate, its likely not to have one. if it has, remove it, block one end off, stand it on end, fill with alloy wheel cleaner, (about £18 per 5ltr bottle), leave overnight, blast out with pressure washer,allow to air dry and refit. I am assured by a contact at a SAAB specialist thats what they do with dpf's and have had 100% success rate. when mine gets so bad, this is what i am going to do, currently its 78% saturated according to op-com.
    bristol
    Quote Originally Posted by barney490 View Post
    Thanks for the info,
    I have a gallon of wheel cleaner, so that's a great tip.
    I have the estate model- why should estate owners be burdened with one?
    I'll get underneath tomorrow and take a look.
    Big thanks for the help
    PRESTON
    oh, be prepared for some crud to come out so be careful where you pressure wash. That oily sooty garbage dont half make a mess.
    bristol
    Thanks again for the warning, my missus hasn't forgiven me for cleaning out my old 2.0 DTI inlet manifold in a corner of the garden, it's never recovered.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
  1. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. P2279 code. 1.9 150
    By Mopar Man in forum Diesel Engine related
    Last Post: 28th April 2011, 20:45
  4. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
p2279-11
Opel DTC P2279-11
p2279 vauxhall vectra
p2279 vectra c
vectra 1.9 cdti 2279 fault
cod engine p2279-11
Opel P2279-11
Vauxhall P2279-11
p2279-11 opel
Vauxhall DTC P2279-11
p2279-11 vectra
Opel P2279opel vectra c 1.9 cdti p2279turbo actuator P2279Opel vectra z19dt DTC P2279-11forare fap bmwvauxhall vectra blog p2279vauxhall fault code p2279-11vectra c p2279p2279 11 slowingp2279 11vauxhall vectra 1.9 cdti fault codes p2279 intake air system leakDTC P2279 OPEL VECTRA GTSp2279 fault code www.vectra-c.comp2279 vectra
