Results 1 to 3 of 3
Thread: Small water leak on 1.9 CDTI
    Jul 2006
    Darlington
    Default Small water leak on 1.9 CDTI
    My car seems to have developed a small water leak. It is only losing half a pint every few hundred miles. After a quick look under the bonet, there is not obvious leaks (I have not looked very hard!!). Has anyone had this before or got any ideas on where to look?
    Any help appreciated?
    Mike
    Mileage : 000
    Are all the hose,s tight, What you might look for too,is staining from the antifreeze a leak might dry on the hot engine so not showing any water leaking, but it should leave a stain. it might be the water pump, can you get the cam cover of to see any obvious signs of a leak. I hope I have been some help.
    Get the system pressure tested mike...it'll not take long and will let them see exactly where the water is escaping to..
  1. Small coolant leak
    By VeccyMike in forum Engine & Drivetrain
    Last Post: 1st February 2013, 12:21
  2. Small Oil LEak @ Turbo. 2.0L DTI
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:58
  3. small oil leak on vectra c sri
    By markmac21 in forum Engine & Drivetrain
    Last Post: 6th May 2010, 18:25
  4. Strange Small Oil Leak 1.8 (Non VVT).
    By John C S in forum Engine & Drivetrain
    Last Post: 21st September 2008, 12:37
  5. cdti water leak!
    By Andy Henry in forum Engine & Drivetrain
    Last Post: 27th March 2008, 09:00
