Results 1 to 2 of 2
Thread: intermitant power loss
    salisbury
    Default intermitant power loss
    Hi guys,
    got the old power loss prob with the 1.9 but not all the time, done all the mods etc and sometimes the power is smooth and other times when pulling out from a junction it is really close your eyes and pray!
    I will get the bottom of this and i am going to replace the rubber hose which goes to the turbo actuator with a metal tube to see if this helps. and as thie actuator is at the base of the engine see if it needs a clean and working correctly. my question is the small white plastic unit which the vacuum hoses attach to, what is it and what does it do? can it be tested. maybe this is at fault.
    cheers
    doug
    2006 signum 1.9cdti 150 auto.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    If the power loss in intermittent then its likely that your EGR valve is sticking - one of mine used to do this.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2.0t power loss :(
    By mez in forum Engine & Drivetrain
    Last Post: 17th May 2011, 13:33
  3. Loss of power
    By Danny 75 in forum Engine & Drivetrain
    Last Post: 20th January 2011, 19:08
  4. Loss of Power
    By maninwales in forum Engine & Drivetrain
    Last Post: 26th February 2010, 13:55
  5. Still loss of power!!
    By jonnynufc in forum Engine & Drivetrain
    Last Post: 5th July 2009, 00:07
