Results 1 to 10 of 23
Thread: brake disc
    Regular Member the fisherman's Avatar
    manchester
    Default brake disc
    ive got a noise coming from my rear end and its a kind of noise like something stuck on tyre going round,but took wheels of today and rolled the hub round it sort of stuck then moved again so thinking maybe it could be a noise from my disc?does this sound common?warped rear disc?
    manchester
    anyone?
    They're fairly cheap to replace, but you could also try swapping the rear wheels to the front and see if the noise moves or if it stays at the back...
    Sodding Typical on Sea
    Because the discs are held in place by a single bolt they can move slightly when the wheel is off and then rub when rotated.
    With the wheel back on try again if it binds anywhere check if the hub is true or if the disc is warped.
    manchester
    Quote Originally Posted by Penfold101 View Post
    it stays done wheel swap
    manchester
    Quote Originally Posted by Derek Mc View Post
    hi m8 ive had wheels of turned hub and well it sticks then unsticks and they should be moving freely am i right?
    With the wheels off it "might" bind a bit, with the wheels on the disc will be held flat to the hub and should not bind, if it still does, you have a warped disc mate or a damaged hub bearing.
    manchester
    ill have to wait till get to garage monday now as left my jack there,cheers mate,its a horrible irratating noise i hate it,it just sounds like something on tire going round thump thump thump
    Sounds like the disc or hub is warped mate, I hope not as I am always sorry to be the bearer of bad news
    manchester
    lol im not bothered aslong as i can find the problem as i can change them myself in work,you got any ideas what disc i would need and price buddy?
  1. brake disc
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2011, 22:28
  2. brake disc etc
    By hoochydady in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2010, 12:41
  3. Brake disc replacement
    By CrisA in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2010, 14:06
  4. Brake disc set
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 09:42
