Results 1 to 10 of 20
Thread: How do you know if your car performing a regen?
    Regular Member bunsen1's Avatar
    suffolk
    Default How do you know if your car performing a regen?
    how do you when your car is performing a regen?
    new to the vec still and other than the smoke bellowing out is there any other signs?
    also i have had a recent DMF done and noticed someone posting about "riding the clutch, can this be defined as im being very cautious when driving now and as stupid as it sounds i wouldnt know how to define it to tee?
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by bunsen1 View Post
    'riding the clutch' is usually defined as holding your foot on the clutch pedal for too long, even resting your foot on the pedal has been known to cause wear. its a bit like riding the brakes i.e keeping the brakes applied at a low pressure on a steep hill, which usually causes them to overheat and fail as opposed to short direct applications which allow the heat to dissipate.
    Full Member Big Sig's Avatar
    Watch the fuel consumption as it will be using a lot more fuel while its doing a regen.
    PRESTON
    bunsen, regen's only occur in Veccy's with a dpf fitted, which are all estates, signums and any veccy with an auto box fitted. So unless yours is an auto, your car wont have one.
    when they do regen, the fuel consuption goes from .1 galls per hour at idle to around 1.8 galls per hour and regens last typically 20 mins. other than that i dont think there is any other indication, although i have heard on early cars, the glow light flashes.
    suffolk
    so what about when your pulling up to a junction and expect to go within 2-10seconds and your using clutch control to edge for and then you stop and hold the clutch down for a few seconds before pulling off?
    suffolk
    oh ok mines a manual veccy 1.9cdti
    Sodding Typical on Sea
    I thought all Euro IV compliant Vectras and signum's had a DPF?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by barney490 View Post
    Yep, Vx dropped the dash indication that a regen was taking place as loads of owners thought there was a problem and kept taking them into the dealers! lol
    No DPF then as yours isn't an estate.
    PRESTON
    hmmm you got me thinking here Derek, thats a very good point, as i understood it it's only the variants i mentioned, Anybody clarify for us????
    TBH I am kind of hoping your right and I am wrong but it doesn't make much sense for the hatch and saloon to lack them
  1. regen
    By marko1966 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2012, 07:36
  2. DPF Regen
    By Andyc6845 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 21:15
  3. what does Regen,,,
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 21:00
  4. DPF & Regen??? WTF!
    By Rab in forum Diesel Engine related
    Last Post: 28th September 2010, 13:05
  5. under performing
    By the undertaker in forum Introduce yourself.
    Last Post: 7th December 2006, 14:19
