Results 1 to 10 of 21
Thread: Help - leaking somewhere from engine
    Regular Member danlat1415's Avatar
    Lancashire
    Default Help - leaking somewhere from engine
    Hi guys.
    For the past few weeks I've noticed a few drip marks on my driveway from underneath the car.
    I didn't think much of it, but over time, the mark on the driveway is getting larger, because whatever is leaking is not evaporating (water etc).
    I'm not sure what's leaking or where from.
    The leak is on the driver side front, about a foot from the edge of car, and about 1/2 foot to a foot back from the front of the car.
    Does anyone have any ideas what it may be?
    My thoughs are it may be:
    brake fluid, engine oil or radiator coolant, petrol? (not too sure on how engine works etc).
    I've not got any warning lights on the car, and it seems to be running fine, but as it's loosing liquid from somewhere, the liquid won't have an endless supply - so I though it best to investigate now before I get any trouble.
    I've got a 1.8 Petrol engine if this helps.
    Dan
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by danlat1415 View Post
    Hi guys.
    Dan
    If i remember rightly the power steering pump is in that area. does the liquid smell at all? best thing is probably to get the engine steam cleaned around that area and look to see what pops up.
    Regular Member Exclusive BV's Avatar
    West Midlands
    I've got the same motor as you. apart from the brake fluid ressy, there is nothing in that corner iirc.
    On our zafira though, water collects under the wheel arch lining and slowly drips out under it's own steam. not had this on mine yet
    Regular Member crespo's Avatar
    Bournemouth
    There are plenty of places for water to run under a car just because it drips from the left does not mean the leak is on the left. Touch the substance to see what it is and have a sniff. It could just be a simple little leak in the radiator that can be sorted with a bit of radweld.
    West Midlands
    Yeah that undertray thingy can be a pain if your driveway is on a slant it will disguise where the leak is coming from.
    london
    Check and monitor all fluids , ..coolant, brake fluid, Engine oil, ATF, Power steering fluid behind the driver's side wing. or it could even be the screen wash .
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you been using your air con alot? Condensation forms on the outside of the pipes etc and can drip down after the car is parked up
    Regular Member Jezzy's Avatar
    S.E
    On some Vec-C's the power steering bottle is at the back of the engine rather than under the O/S wing.
    Northampton, UK
    That was my first thought.
    Lancashire
    Thanks for your replies guys:
    air con (condensation) - no I haven't had this on because it hasn't worked for about 3 years and I haven't got round to getting it sorted. winding window down was a temporary fix.
    screen wash - this is on the passenger side in my car, next to battery
    engine coolant - this does mysteriously go down slightly over time, but that's filled right at the back of the engine, so not sure if it'd leak near the front driver wheel.
    power steering fluid - I know this is located just infront of the driver wheelarch. I had to top this up about 6 months age because the warning light came on that.
    engine oil - I'm checking this, this morning so not sure yet.
    brake fluid - where is this located? Had full brakes replaced about 1-2 months ago. Not a kwik fit, so hopefully they should be fine - but where would I check this to see if something isn't connected right?
    ATF - what's this?
    Dan
  1. Leaking oil :(
    By Liamalone in forum Engine & Drivetrain
    Last Post: 25th September 2012, 16:25
  2. 2.2 16v Petrol leaking oil on side of engine
    By albeat89 in forum Engine & Drivetrain
    Last Post: 9th April 2012, 23:28
  3. Air con seems to be leaking :(
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 20:14
  4. air con rad leaking
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 19:05
  5. Leaking 12v....
    By david.aka.judas in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2010, 19:04
