Thread: rear spring removal
    Runcorn
    Default rear spring removal
    In order for me to remove rear spring. Which bolt do I remove. Is it the one at the bottom of the shocky or the bolt and and nut at the end of the Swing arm or whatever yer call it.....Cheers
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    WGAF#5
    yep as above...that covers it nicely
    Runcorn
    Thanks all. Just got on with it and done it. Both front and back done. Jobs a goodun. Cheers.....
    Regular Member Jezzy's Avatar
    S.E
    You've changed all 4 springs in 2 hours? Blimey.....
    Runcorn
    Nah Jezz. Did front last weekend mate, just needed to get on with back. 1st one was a pain as didnt really know what I was doin. 2nd took 20 mins if that. Easy job when yer know how. Prob do both in 45 mins. Front 2 a little more difficult as you need spring compressors. Rear 2 was a matter of removin a bolt and removing and replacing spring. Jobs a goodun.
    S.E
    Quote Originally Posted by colashbury View Post
    That makes more sense - I did mine a few weeks ago and certainly took more than 2 hours for all four, so I was wondering if I was a bit slow compared to you... lol
    Runcorn
    Nah, 1st in both cases was a bit difficult but 2nd so much easier. Had a bit of a rattle at the back and thought it may be the springs. Seems a common fault this rattle. Anyway, the front nearside spring went a week ago so had to change. Thought I may as well do em all. Found the nearside rear one broken as well. Still got this annoying rattle though. Only really when goin over rough ground or pain in the arse bumps in the road. Think it maybe the exhaust as all rubbers seem to be a bit soft.
    Thought I would get all jobs done and give it a service.
    One to do though. Seems another common fault. Front passenger door shows as open when closed. Everytime yer take off it gives yer that annoying sound to tell yer that the door is open.....
  1. 314mm brake pad removal spring
    By DHobbs in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2012, 00:19
  2. Front Spring Removal Question
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 01:46
  3. 2 Front SRi / 1 Rear Sri / 1 Rear Ls Spring
    By jordib in forum Parts for sale
    Last Post: 16th May 2010, 20:21
  4. Rear spring removal
    By s1nglef1sh in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2009, 23:59
  5. Rear Spring Removal? Help?
    By mototrain in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2009, 23:58
