Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: hid xenon
    Regular Member vectra_'s Avatar
    australia
    Default hid xenon
    would these fit my 2003 vectra ??
    http://www.hids-direct.co.uk/hid-con...its-p-445.html
    my left headlight went out yesterday and i called the dealer today and they said to get it replaced its 85 australian dollars.....
    so i decided to get these instead...
    50w Vauxhall HID Conversion kits
    - Color Temperature: 6000k
    - Vauxhall: Vectra C
    Regular Member mikeeaston's Avatar
    widnes
    what sort of headlights have u got cos 85 australian dollars is like £50 and a headlamp bulb is about £5 if u have normal headlamps then yes this kit will fit if u already have factory fitted zenons then no this kit will not fit
    australia
    these ones ive got...
    with shipping its £98.82
    its around 140 australian dollars i think..
    widnes
    yes they will fit as u dont have the factory fitted zenons
    australia
    do these come with the glass of the headlight ???
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    These kits effectively fit in place of the standard bulb.
    You remove your normal bulb... assemble the kit (one kit for each side).... fit the newly supplied HID lamp into the hole left by the old bulb (using the modified metal clip supplied).... then the old wiring plugs into the ballast unit of the kit (metal box usually about 4x6 in roughly).
    In reality there's a couple of other minor bits to do but the whole job from opening the box to switching on new lights seems to take most on here about 1 hour tops.
    australia
    so it comes with two kits (two boxes), one for each side...?
    and does anyone have a pic 6000k 50w?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by vectra_ View Post
    The kit you get is for one car complete -
    1 ballast unit per side
    1 lamp per side
    1 warning canceller per side (if specified)
    1 modified lamp retainer per side
    Possibly some cable ties and ballast mounting brackets.
    australia
    sorry i dont no too much about these stuff..
    do i need a projector for it ? would it look better with a projector?
    and hid means xenons yeh??? :s :s
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The standard kits where the lamp is shown as H7 fit to a normal Vx/Op/Holden vectra, both pre and post facelift.
    The normal dipped beam part of the headlamp unit is mounted in a projector unit - that's the bit with a whacking great magnifying glass on the front of it.
    You can get kits/lamps ofr non reflector units, they are called H7R but I'm 99.9% sure all Vectras dipped beam units are housed in projector units.
    Many people use the terms 'HID' and 'Xenon' to mean the same thing.... but to be correct, you can get 'normal' headlamp bulbs filled with either halogen gas or xenon gas - both are equally pathetic when compared to an HID system.
  1. To Xenon or not to xenon
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2011, 15:28
  2. Xenon - one up, one down
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2008, 14:49
  3. Xenon
    By Mrsan in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 22:36
  4. xenon kit
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2007, 10:33
  5. Xenon/HID kit X5
    By Marky in forum Parts for sale
    Last Post: 29th March 2007, 12:58
