Results 1 to 9 of 9
Thread: Twitchy Rear End
    Shropshire
    Default Twitchy Rear End
    Hey,
    I've got a 2003 Vectra hatch, not had it long and have noticed its got a twitchy rear end - over bumps and uneven roads it feels very bouncy and light and just not planted on the road, and if it hits a grid or the camber is different on the back wheels it'll kick to the right.
    I've read through the forum and think the "rear upper arms" are on there way out
    I did the test by yanking on the top of the rear wheels and theres no crunching noise only the noise of me trying to move wheel.
    The rear tyres were shot so i've had new ones on the front and put the front with 80% on the bcak and this has helped but not stopped the problem.
    Am i right in thinking its the URA's or is it the shocks ??
    As when pulling off at low speed you can just about hear a slight noise but its not a knock
    Any help appreciated
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The noise of pulling the top of the wheels will be a clunking noise, make sure the car is on the ground when you do this check.
    Failing that the chances are it is the shockers that are playing up as these are the two major weak points on the Vec-C's rear suspension (barring broken springs but the symptoms you mention kinda rule out broken springs)
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Probably is the upper control arms - mine passed the "grab the tyre and see if it moves" test, but I changed them anyway and found that the outer bush was like jelly.
    Regular Member paul wingnut's Avatar
    Mar 2009
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    Year : 2008
    most likely to be rear shockers
    Oct 2007
    nottingham
    had this on my dti changed shocks problem gone.
    tommy
    Regular Member old cruiser's Avatar
    slough
    I also had this on my old Omega, changed rear shocks for some KYB gas shocks and problem solved.
    Cheers Pete
    Moderator paulhb's Avatar
    Dec 2007
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Rear shocks mate my outer bushes seem soft but not an issue for the MOT and the new rear shocks sorted out the bouncing
    Shropshire
    Thanks for the replies guys
    Looks like i better get some new rear shock's, might change the upper suspension arms too as it's all apart and will be peace of mind they've being done - job doesn't look to bad to do, might give it try.
    Cheers everyone
    Lisa
    Jan 2010
    FIFE
    I had a similar problem when driving in the highlands car felt dangerous changed the shocks, car sorted, rear end planted to the road, got caught speeding. ?????
  1. twitchy rear end
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 17:51
  2. Really twitchy around corners
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2011, 22:33
  3. Vec C twitchy Front end
    By Grovercus1969 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 20:10
  4. Twitchy front end on 2.2 sri 03
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 09:53
  5. twitchy signum
    By Martybhoy in forum Handling & Braking
    Last Post: 18th February 2009, 21:32
alloy wheel thread repair kit
