Thread: any ideas on this pipe guys
    PRESTON
    Default any ideas on this pipe guys
    had the top cover off the engine tonight (1.9 cdti 120) and noticed the small vac pipe over the vacuum pump, red arrow pointing to it in the pic, was sweating oil. So took it off to give it a wipe and check for splits and its full of engine oil..... does anyone know if this is normal??? or has the cam seal gone between the vac pump and the cam cover?
    PRESTON
    thread dissapeared, cheers guys
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Its a vacuum pipe mate and not an oil one and is talked about as a replaceable item in this thread:
    http://www.vectra-c.com/forum/showth...t=vacuum+pipes
    PRESTON
    cheers paul, i know its vacuum, thats whats bothering me, is shouldnt be full of oil and it is. What i cant figure is how oil is finding its way in there.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    whats it connect between mate? I'm not sure the layout of the 120 engine
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    PRESTON
    hey plasma, as far as i can see it goes from the bottom front side of the vacuum pump, then connects to the metal pipe in the pic,which then goes down the back of the engine to the vacuum box.
    PRESTON
    UPDATE,,,,,, had it checked by two local mechnaics and they both say its the seals in the vac pump failing, allowing engine oil into the pump. There should be NO oil in the vac pipe at all,so if any of you guys experience the same thing,,,,,,,pumps knackered!!!
    Got it on order as its dealer part only and will be changing it next sat.
    PRESTON
    had a look today at next saturdays job, swapping vac pump, looks like just three bolts but does anyone know how to release the brake servo vac pipe from the pump. its the one in the pic with the yellow connector at the top of the pump. I just cant figure it out and dont want to break it.
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. Rear washer interior pipe help/ideas
    By soulie in forum Bodywork & Interior
    Last Post: 14th April 2011, 12:11
  3. any ideas guys
    By shaun260589 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 23:37
  4. immobiliser trouble any ideas guys
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2010, 15:37
  5. Any ideas guys and gals?!?!?!?!
    By Mrs D in forum General Chat
    Last Post: 28th March 2006, 12:53
