Results 1 to 10 of 13
Thread: my 2.0t sounds like a tractor
    connahs quay
    Default my 2.0t sounds like a tractor
    hey all
    When i start my car it idles and makes noises like a tractor. then when i accelarate it sounds as if the exhaust is rattling. no smoke or anything and still goes well
    very embarrasing like my spelling!!!
    anyone experiance this?
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    not to scare u or nowt but mine sounded the same apart from the exhaust sound when my chain had slipped. like i say not to scare u but i would say the timing chain. what mileage u done mate.
    connahs quay
    Hey. It's done 85k. Alot of rattle from exhaust
    Nov 2007
    telford,
    i would say that the chain is knackered mate at that mileage if not been changed yet. like i say not entirely sure about ur exhaust though.
    Have you checked your connections/joints on the exhaust system i.e. cat/downpipe and downpipe/centre section as if they are a bit loose it can sound a bit like what you're describing, especially with the exhaust rattle. Check those out first before you start going down the route of timing chain investigations as I doubt if it would be that with the symptoms you're describing.
    prestatyn
    hi mate mine sounded like a tracotor the other day where the turbo bolts to the manifold 2 bolts i fallen out i still have a ittle exhasust ratle now but when driving engine is so qite again
    Quote Originally Posted by robsriturbo View Post
    ...where the turbo bolts to the manifold 2 bolts i fallen out
    Yep, that's also the other place to check for anything loose.
    WGAF#5
    and at that age and mileage i would have a poke around the exhaust heat shields ...possibley fractured on its mounts ....one of 4 under the vehicle
    by the time mine went at the beginning of the month i had removed all 4
    Nov 2007
    telford,
    told u not to let me worry u.lol
    connahs quay
    Been to garage, the whole ofthe exhaust is rotten and hole in one of the backbox.. hmms will need to look for new exhaust. vauxhall want 1100!!! an after market one will be cheaper.. any ideas??
  1. 2.2 Direct Tractor!
    By Munnzie in forum Engine & Drivetrain
    Last Post: 12th August 2012, 12:47
  2. Tractor accident
    By bobssignum in forum The 'Off Topic' room
    Last Post: 18th March 2011, 16:46
  3. Tractor lotion
    By alex_c in forum Diesel Engine related
    Last Post: 7th February 2010, 15:59
  4. Tractor Racing
    By Ben H in forum Comedy & Humour
    Last Post: 24th January 2007, 18:47
  5. LEXMAUL'D Tractor
    By armoured farmer in forum Quick Photo Album
    Last Post: 20th July 2006, 08:18
vectra sounds like a tractor
