Results 1 to 10 of 11
Thread: Remap at home
    Romania, Bucharest
    Default Remap at home
    Hello. How can I remap, at home, my ECU from a Vectra C 2002 with Z22SE, while on eBay and on another sites exist a lot of flashing tools? Can this be done with Galleto or KWP2000+? And if this can be done with one of those tools, and if I will be able to save the original map file from ECU, who may can modify it for me? Has anyone saved a modified map file compatible with Z22SE? To remap my ECU at a specialized dealer in my country (Romania) it's so expensive. Any ideas? Thank you in advance!
    Regular Member crespo's Avatar
    Bournemouth
    It can be done with KWP2000 but you run a very serious risk of killing your ecu.
    I would advise against any DIY remap to be honest. Not saying it has not been done but there have been more than a few instances of ECU deaths through a DIY ECU flash.
    Those Galleto and KWP flash tools you see on ebay are chinese clones. The real deal would cost thousands to buy and i would 100% not install any software that comes with them.
    You can buy maps online and use the flash tool to install them but Maps are not cheap either but then they are designed to be used over and over again which is where you make the money back.
    It is really not worth remapping your Z22SE because the gains will be minimal, probably 8bhp at best but with a bit better low end pick up. Buy a decent exhaust and go for the placebo effect as the noise will make you think you are going faster than you are.
    Romania, Bucharest
    On several sites I've seen that gain power is between 10% and 15%, but the remap improves the torque. I saw that at this engine can not be done more then derestrict, K&N filter, modify TB, and exhaust. Any other ideas? Thanks for the advice.
    Bishops Stortford, Herts
    www.z22se.co.uk for all your Z22se tuning needs
    The ecu isnt very well cracked as there is marginal market for it unless you aer supercharging it.
    Romania, Bucharest
    Does canceled anyone the EGR? What's the improvement? If I'll canceled from ECU, I'll still need for the EGR cheater? My Vectra C has a lag when I shift the gear from step I to step II and from step II to step III at big rpm. Sorry for my english!
    Romania, Bucharest
    Wich of those tools should I use to read/write ECU files from my Vectra C 2002 with Z22SE engine, Galletto 1260 or KWP2000+ ?
    Mar 2011
    Bulgaria
    Im looking for map file ..... Vectra C 1.9 cdti 2005 150hp
    Is there anyone did remap at all ... ??? Looks like only talking... Could not met anyone have a map file.... not at all, however i believe 1.9 cdti is a common engine...
    Any idea what is the map file extension
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by kingarthas View Post
    If you want to map that at home mate you want the BSR unit. They send you the file via Internet and you flash it to the car with there hand held unit, not cheap though.
    Mar 2011
    Bulgaria
    Good database with tweaked map files 10Euro each..... however lacking 1.9cdti
    http://www.obdcar.com/power-ecu-tuni...s-sitemap.html
    Vehicle : SRi
    Mileage : 137000
    Its a fiat engine, they call it a JTD
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. 2.0t remap from remap science bradford
    By stefan7153 in forum Petrol Engine related
    Last Post: 4th May 2011, 22:03
  3. Replies: 71
    Last Post: 30th April 2008, 12:38
  4. ah! home sweet home!
    By pogo in forum General Chat
    Last Post: 20th October 2007, 21:03
  5. home sweet home aarrrrggg i love it !!!!
    By big phil in forum Introduce yourself.
    Last Post: 9th June 2005, 08:04
z22se remap diy
https:www.vectra-c.comforumshowthread.php113573-Remap-at-home
z22se remap injector times
map ecu z22se
mapa do vectra c sri
ecu flash tool z22se
1.9 cdti vectra map file
