Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Problem with 2003 Vectra dti
    N. IRELAND
    Default Problem with 2003 Vectra dti
    Hi All
    I drive a 2003 vectra 2.0 dti 100bhp and as past week on the lower gears I am losing power and it’s a lot noiser or has a hum when driving, also bit smokey when taking off..
    And today I found its got worse and is now dangerous to drive…
    Main Vauxhall dealer wants 60 plus vat to plug in it just to find the fault…
    I think it may be the egr valve and have read the section on this but my vectra's egr
    Is different but the one in the tutorial which I think is for the newer cdti models..
    Anyone able to advise me on this thanks
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by molloy View Post
    Hi All
    give egr a clean and boost sensor, do you know how to remove egr?
    also prob worth getting some 10k decoke stuff
    any warning lights on?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Suer there was a post about doing the EGR on a DTI some where
    Irmscher Insignia CDTI 130
    N. IRELAND
    Hi
    yes the yellow car with spanner in it, engine management light i think is on all the time now.. i know how to remove it -there is 2 bolts holding it..
    however i don't know how to clean this one, . i saw the tutorial on the later one which was very good but mine different and can't seem to find the step by step instructions/photos on it
    thanks
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    listen mate, if your taking EGR out do the intake manifold aswell, mine was well cocked up .strangelley enough just on the left side of the EGR valve . that way youdo the boost press sensor aswell only 1/2 days work with cleaning aswell.....good luck.
    N. IRELAND
    ok but how do you clean these correctly
    do you have to disassemble it and if so how do you go about it?
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Hi All
    Have you check here
    http://www.vectra-c.com/forum/showthread.php?t=60856
    This details the removal and cleaning of 2.0 DTi egr.
    Oct 2009
    Sandwell
    ive got to do my manifold how do u get it off
    East Midlands
    Quote Originally Posted by chris1804 View Post
    Mate before you remove the EGR for cleaning,have a look at both iintercooler hoses left and right side for ant splits,and also check the rubber joints at the ends of the thin white pipes,they tend to split and this throws up the the spanner light .
    Oct 2009
    Sandwell
    Quote Originally Posted by macdad View Post
    My cars alright I just want to clean manifold just to give it a good clean and see if it runs any better
  1. Vectra C Y20DTH 2003....is this an ECU problem??
    By Acebob666 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 17:22
  2. vectra 1.8 2003 tickover problem....help...
    By gazman in forum Engine & Drivetrain
    Last Post: 27th October 2009, 18:19
  3. Problem with vectra-c 2003 dti
    By m15bfe in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 17:41
  4. Vauxhall Vectra 2003 2.2 SRI CD problem
    By Gary1985 in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2009, 23:48
  5. Vectra 2003 V6 3.2 Idle problem
    By joseantoniovalle in forum Introduce yourself.
    Last Post: 18th August 2006, 16:23
