Thread: Stuck Rear Wheels
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Default Stuck Rear Wheels
    Morning All
    I have a problem which I am sure you will be able to help me with
    My rear wheels are weld on to the hub. I have tried WD40 & a big hammer but no luck.
    Please all ideas welcome?
    Regular Member Jezzy's Avatar
    S.E
    Put all the wheel bolts back on the wheel, lower the car to the ground, loosen the bolts a little bit, then drive a few yards at slow speed - the forces on the wheel will shake it loose as the bolts aren't holding it tightly to the hub.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    or get a bigger hammer
    Regular Member eaglepva's Avatar
    Up North
    I had this problem on my car when doing the rear brakes. i jacked the car up on the trolley jack and also put a axle stand under the car as a bit extra support then used a sledge hammer and gave it a good whack, wheel came straight off.
    Sodding Typical on Sea
    It is a real issue, I have now taken to removing the wheels every few months and re- copper-greasing them after a massive issue on my Saab in the middle of winter, it is a ballache but in the long run probably worth it to me at least.
  1. Removing rear hub? HELP! I'm stuck!
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 20th August 2012, 10:38
  2. Annoying squeak and wheels stuck on!!!
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2011, 15:00
  3. Rear Seat stuck
    By JamieD27 in forum Bodywork & Interior
    Last Post: 26th September 2010, 15:21
  4. rear wiper blade stuck to car........?
    By VectraSri3 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2010, 12:07
  5. wheels stuck!
    By alex in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2009, 09:38
