Results 1 to 10 of 13
Thread: thinking of blanking the egr....help needed
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Default thinking of blanking the egr....help needed
    can some tell me where i put the homemade gaskets?
    there is a pipe of the exhaust manifold that goes round the side of the head on to the egr valve, where do i put the blocking gaskets???
    do i remove the egr completly and blank all the pipes?
    or do i leave the egr in place and just slip the new homemade gaskets inbetween???
    cheers guys
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by big rich View Post
    cheers guys
    Think its this option Rich,
    birmingham
    Engine : 3200
    Quote Originally Posted by spennny View Post
    so do i do the 3 pipes coming off it?
    also do i leave it plugged in???
    im well puzzled
    where is dan when you need him lol
    Blantyre
    Yes i think you leave it plugged in , just blank it, dunno about the pipes, mine doesnt have pipes
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    You will need to place the solid gaskets but leave connected. It will show a fault light but thats it.
    birmingham
    Engine : 3200
    Quote Originally Posted by CHRISK View Post
    so i will need to make 2 gaskets for both pipes coming off the egr?
    or just one for the inlet side?
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    My 150 has inlet from exhaust, this is the one i would blank, and then outlet to manifold, which I would not think is necessary, but may blank whilst egr was off.
    birmingham
    Engine : 3200
    thank you
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Mileage : 66000
    You have the option of blanking the exhaust side of the EGR, or the inlet manifold side - both will have the same effect, but I chose the inlet manifold side as it would be less suseptible to the hot gasses and would 'seal' the EGR best, as it rules out any leaks with the EGR itself (which does happen with the gold coloured piece at the end).
    You can make a gasket yourself, then simply remove the EGR valve as per normal, but when re-fitting, fit the blanking gasket with a std VX gasket either side (to make sure the seal is ok) then it will be blanked - leave it connected though.
    Hope this helps.
    birmingham
    Engine : 3200
    Hope this helps.
    cheers m8, made a gasket out of an old alloy number plate
    the car starts faster, boosts nice and the best thing its stopped goin in limp mode
    i would recomend it, thanks for your help guys
  1. Thinking Big, Thinking Transplant
    By paddyvectra in forum Diesel Engine related
    Last Post: 14th August 2011, 20:41
  2. Thinking of getting a GID (advice needed)
    By Rorschach in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:40
  3. Blanking egr
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 18:21
  4. Egr blanking
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 30th March 2011, 00:06
  5. EGR blanking
    By ctj in forum Engine & Drivetrain
    Last Post: 1st January 2011, 02:17
