Thread: F17 Gearbox oil Change
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Default F17 Gearbox oil Change
    Changed the gearbox oil yesterday, car has done 111k in three years and the difference is marked, much more slick and less notchy shift. Used a genuine gm gasket and genuine gm oil as the lot came to £16. Why they didnt put a drain plug on these boxes is beyond me, suck bad design. To anyone who has a high miler and hasnt done it yet i'd say its a very worthwhile piece of maintenance no matter what vauxhall say.
    what engine is the f17 gearbox for ??
    Nov 2007
    Northants
    1.8, iirc rest of the range run the stronger boxes.
    Regular Member cphaza's Avatar
    Hertfordshire
    Our 1.8 life on 54plate went tits up over the weekend, sound like a diff problem from what the AA man described. Its sitting outside the garage waiting its turn. Obviousley I need to buy another box, are they all F17's on the 1.8 accross the MY's or do they vary at any point? Im guessing it must be stamped on them somewhere....
    Nov 2007
    Northants
    They are all F17+ gearboxes but there are quite a few different types of this gearbox produced for various GM cars.
    Hertfordshire
    i see, and I'm guessing they are not interchangable between different gm cars?
    Nov 2007
    Northants
    Depends on how much work your willing to do, had a 59 astra f17 fitted to a 06 vectra c and it wasnt a direct fit, would be best to source one from a vec c or have yours rebuilt, local gearbox place charges about £350 for a exchange box as a guide but a 2nd hand box is anywhere from £50 to £200.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
f17 gearbox oil
f17 oil change
f17 gearbox oil change
f17 fluid change
vauxhall f17 gearbox what oil
how to change f17 gearbox oil
gearbox oil for vectra c f17
f17-5 gearbox oil
gear oil vectra c f17 change
how do I change the oil on a f17 gearbox
adjust f17 gear linkage
f17 oil replacement
oil change f17 gearbox
gm f17 transmission oil change
f17 gear selector suck oil
