Thread: caliper & handbrake cable
    preston
    Default caliper & handbrake cable
    hi
    just bought some 292mm calipers from scrappy.
    removed old cable ok but seems there is a black gromit through which the cable passes as it goes through the caliper and on to the attachement point.
    Is this gromit supposed to be removed before fitting a new handbrake cable or does the cable kit contain the new gromit.
    and how can i remove old gromit....
    several beers and worried about taking heavy tools to caliper to remove this part
    many thanks
    mike
    Jun 2007
    Scotland
    spray some WD40 on area where grommet passes thru the fixing point on the caliper. using a pipe wrench or pliers firmly hold the grommet and turn to allow the WD40 to penetrate and then pull the grommet and cable out and away from the fixing point.
    preston
    Thumbs up thanks
    thanks for that
    which way does gromit come out?? towards the front or rear of the caliper?
    wd40 at the ready
    mike
    Jun 2007
    Scotland
    pull out in the direction of the handbrake
  1. handbrake cable
    By mbtech01 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2013, 16:47
  2. Handbrake Cable Tightening
    Last Post: 23rd April 2012, 10:49
  3. Handbrake cable
    By peadar in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2008, 07:57
  4. handbrake cable
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 12:49
vectra c handbrake cable removal
vectra c caliper removal
vauxhall vectra how to remove handbrake cable from calipervectra c handbrake cable fixing to callipervectra c rear brake caliper how to remove handbrake cablevectra c caliper replacement and handbrake vectra c handbrake cablehow to disconnect hand brake from vauxhall Vectra 2008how to comnect handbrake cable to caliper vectravectra c handbrake cable bush
