Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: black soot/smoke under heavy load
    Liverpool
    Default black soot/smoke under heavy load
    I have a diesel express box in car, and under heavy acelleration i find it does pump out alot of black/soot smoke. I know this is the 'norm' for diesels, but it does seem excessive if i'm honest
    does anyone know how to get a cleaner burn?
    appart from not accellerating hard that is!!!
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Im also intrested in this thread as my car is doing the same any ideas any one
    Mar 2007
    GB
    with the tuning box it will emit plenty of smoke. also, the airbox mod will make some cars smoke more.
    However, I haven't got a box on my 150 now, and i can't see any trace of smoke at all in the mirrors under any load, even under harsh acceleration.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    As i said in Winnie's thread with a box it is normal., however you say it is a bit more excessive - by how much? is it to the point where the view from the rear window is nearly blocked?
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No smoke no poke
    stockport
    kings lynn, norfolk
    I've had the box on now for 5months and all has been well I saw the odd puff when I booted I after a long journey and that's it but now if I am in 3rd gear doing 1300 revs if I put my foot down to the floor the turbo takes ages to spin up and there is plumes of smoke from the exhaust I am not loosing any boost but it just takes ages to spin up and no where near as quick as I was a week ago the smoke is worse now as when I floor it in any gear there is plumes to the extent where the person behind me' gas to put his foglights on so yes its bad any ideas could it be the dpf getting clogged up causing slow acceleration and heavy smoke
    Regular Member david.aka.judas's Avatar
    Suffolk
    take the box off, the engine and emmisions are specifically designed by vx to be a balance of smoke and power.
    you want more power, then you get more smoke...
    Full Member Big Sig's Avatar
    The box makes the car produce more smoke as your burning more fuel. It's not surprising that it will clog the dpf up quicker.
    kings lynn, norfolk
    hi just a update checked pipes all are fine and the dpf saturation is 94% i take it that the dpf is nealy blocked up then that is just after a blast through the gears and back home again
    if the dpf is clogged up will this cause black soot under full throttle i mean excessive smoke
    also what % saturation will the engine managment light come on to tell me that it is blocked
    will the saturation cause the lack of power through out the rev range
    thanks i am going to take the tuning box off now and take her out see if the smoke is any better i will post once back any ideas please help as i ned the car for a long distance trip on thursday
  1. Occasional Heavy Blue Smoke (150 CDTI)
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 18th September 2012, 12:52
  2. Heavy smoke on start up-random
    By merikiito in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:45
  3. Black soot around exaust pipe
    By TopRod in forum Detailing and Car Care Discussion
    Last Post: 5th July 2011, 11:04
  4. Black Soot Everywhere!
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 14:17
  5. Black soot/smoke when revving the engine
    By tigro in forum Engine & Drivetrain
    Last Post: 30th October 2010, 14:41
vectra c soot removal
