Thread: Handbrake problems
    Regular Member Dazzy2006's Avatar
    Notts
    Default Handbrake problems
    This car is getting beyond a joke for problems
    I left the car on the drive earlier with the handbrake fully on when i just went out the handbrake is still on but it had rolled into a post and now i have a lovely pole shaped dent on the corner of the bumper, as far as i'm aware it has had the handbrake modified but what is the best way of telling? i have a sticker on the sun visor going on about parking and assume that means its been done, Also what else would cause it to fail in such a way?
    Also does anyone have any suggestions on how to get the bumper back into shape?
    Thanks guys
    If the hand brake was still on then it's not failed like they were as they used to release. Maybe read the sticker and leave it in gear? Then get the handbrake fully checked out.
    Regular Member signumturbo04's Avatar
    SCOTLAND
    if its just a dent in the bumper you can heat it from inside with a hairdryer and it should pop back out, depends how bad it is though
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    If the hand brake recall work has been done, the brake lever should 'take' on the first or second 'notch' on releasing it and letting it 'drop'. Before the recall it was prone to 'dropping' completely to the floor on release. You can test this with the car parked, though preferably not on an incline in neutral.
    PRESTON
    i always press the footbrake, then apply the handbrake and leave in gear as a precaution.
    11 Post(s)
    Quote Originally Posted by Dazzy2006 View Post
    The sticker was sent out by post to owners of Vectras & Signums. It doesn't mean any mods have been carried out.
    No offence, but have you read what the sticker says - particularly the bit that advises to also leave the car in gear? The same advice is in the handbook, as well as getting a mention in the highway code (part 252)
    Notts
    I am leaving it in gear from now on but i find that strange because when i passed my test leaving the car in gear was a big no no and its probably going to take a while for me to get used 2, this is the only car i have ever owned that i dont trust the handbrake on.
    Thanks for the hint with the hairdryer,i have managed to get 90% of it out but the bumper will have to come off at some point to get the last bit out.
    My handbrake comes up about 4/5 clicks , is there any way of adjusting them? the brake pads were supposidly replaced last november but the discs are looking dodgy so maybe that will also have something to do with it, this morning i pulled the handbrake on then went to the back of the car and pulled it towards me and it did a bit of groaning but moved
    Notts
    Anyone
    11 Post(s)
    It's advisable to start the car with your foot on the clutch as you're not having to turn over the gears in the gearbox - saves drain on the battery, which can make all the difference in winter.
    4 to 5 clicks is the norm.
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  2. Anybody else had any problems with their handbrake sticking in the cold?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 13:44
  3. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  4. Handbrake problems
    By petrolhead55 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 23:20
  5. Not Just Vectra Handbrake Problems...
    By CorsaVan in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2007, 18:48
