Thread: Safe guard
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default Safe guard
    I know there has been a recent thread of a similar topic but I have a slightly different problem.
    Recently i have found the car alarm going off randomly and when entering the car and turning on the ignition it comes up 'check safeguard'.
    I can stop this happening by pressing the button on the dash before exiting the car then alarming it in the normal way with the fob.
    Is there a simple fix for this or will I have go go down the normal route of eliminating hundreds of possible faults?
    Full Member spennny's Avatar
    Blantyre
    Start with the fuses in the boot, always good to start with fuses,
    Big 30 amp one in the left hand side, can you think of anything you have done to start the fault or was it just there
    Nov 2009
    south wales
    Fitted traction control switch and rear parking sensors?
    Cant see that affecting it?
    Blantyre
    Do your parking sensors BEEP when you turn the traction control on
    Nov 2009
    south wales
    Quote Originally Posted by spennny View Post
    Not as far as im aware.
    they are the onesthat wire up to the reverse lamp
    Blantyre
    Did you wire the earth up correctly, cut any other wire by mistake /
    Check the fuses in the boot mate, good starting point
    Jun 2006
    Kirkintilloch, Scotland
    Default Safe Guard error message
    Quote Originally Posted by larrysSRI View Post
    Since I fitted a traction control switch a couple of days ago on my 2004 elite estate I also have the "check safe guard" message every time I switch on the ignition.
    I'll check error codes a fuses at the weekend but could there possibly be a connection with me fitting this new switch?
    Thanks,
    Dave
  1. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  2. Power Tail Gate & Safe Guard
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2012, 14:49
  3. Cars says check safe guard
    By Sri-chris in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2011, 23:35
  4. 'Safe Guard' message (Codes inc)
    Last Post: 20th April 2011, 00:30
  5. Safe Guard
    By Marc Hutton in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2008, 17:45
