Thread: z22yh missfire on cyl 4 help
    Jul 2009
    wishaw
    Default z22yh missfire on cyl 4 help
    Hi there i have a 2.2 Vectra direct z22yh i have had a problem with the car the past few months every now and then when i put the foot down the car would just hesitate to go as if it was missfiring then today it got worse the car was constently like it was missfiring and the emissions light came on i pulled over and turned the car off then it started again ok and ran perfect again all the way home.
    I took the car to my mate and his fault reader says the there was a missfire on cyl 4 he suggested chaining the coil pack? will this solve me problem or could the be the dreaded fuel pump on the way out?
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    check your plugs are clean first if thy are it sounds like the coil packs gone, if not clean then change the plugs
    Regular Member mikeeaston's Avatar
    widnes
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Swap the plugs around, if the misfire moves then you know if its the plugs.
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
  1. 2.8 Missfire
    By Ziggy in forum Engine & Drivetrain
    Last Post: 27th June 2012, 20:07
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  5. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
